Flatron W2240s power board oscilating voltage
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hi, i have a problem with Flatron W2240 and tu68c8-7a power board, board should have +5.1V, +22V for logic board and inverter but my voltages jump from +2.8V to 5.2V on 5V rail, and from 21.7V to 22.5V on 22V rail when logic board is connected, and when its unpluged they oscilate +/-0.2V from nominated voltages...
    Anyhow, changing caps didn't help, so i tested for shorts and found nothing shorted. I powered the logic board with external +5V and monitor worked
    After that test Power board magically started working, and the monitor worked for 2 weeks on its own Power board with no problem, till today...
    Again, +5V rail is going from +2.8V to +5.2V
    +22V rail is going from +21.5 to +22.2V
    Logic board draws 100 to 200mA on 5V when connected to external PSU and the voltage oscilate without ccfl lamps being connected to the board
    Anyone has suggestion what to do?
    Re: Flatron W2240s power board oscilating voltage
    We need pictures of the board.
    Did you check/replace the start-up/running cap in the primary side of the circuit?
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
      by momaka
      03-15-2023, 10:17 PM
