Dell 1702FP LCD Fix from FixYa
  • DixiePenguin
    • Mar 2008
    • 77
    • Philippines
    We had a Dell 17" LCD with flashing power button, and alternately flashing setting lights. Opened it to find no obvious bad caps but lots of surface mount
    capacitors. I went on FixYa just on the off chance. One answer offered was the "take it to a shop", but another GREAT individual offered the solution and EXACTLY which surface mounts to replace.
    "Replace two 10uf capacitors on control board C604 and C507."
    My son says he also has a video on his home page showing the work. It is linked to one of his solutions on his profile page.
    Any way my son got the soldering iron and inside 20 minutes had replaced the two caps and was using the lcd.
    So hats off to "hdaghigh" on FixYa.
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Dell 1702FP LCD Fix from FixYa
    Good tip, straight to the point!
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • weirdlookinguy
      • Sep 2007
      • 1638
      Wow, usually FixYa is a bunch of illiterate morons telling you to buy a new one. Good to hear.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I'm not real impressed with FixYa either.
        Pops up in every damned google search and RARELY has anything that's even pertinent to my search let alone actually useful.
        DixiePenguin, no disrespect intended. I'm speaking about FixYa in general.
        Mann-Made Global Warming.
        - Dr Seuss
        • EGuevarae
          • Nov 2008
          • 1336
          PCBONEZ, I know what you mean. But if this is a tested solution, this will be one good among all the crap that normally is answered there.
          • GeForce GT1050
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I agree.
            - Dr Seuss
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
              Dell Thunderbolt Firmware
              by SMDFlea
              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
              The SKU is in brackets (****)
              EDIT: NVM65...
              01-26-2025, 06:22 AM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
