IBM/Lenovo M90Z CCFL Replacement
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I got 3 Lenovo M90Z AIO systems in functional condition. They were free for a reason though, the displays are dim and have a greenish hue.....dead ringer of severely degraded CCFL tubes. They are I5's with 8gb RAM in good physical condition....so....now to the question:
    The panels are Samsung LTM230HT03, 23". In all my years, this is my first attempt at replacing CCFL tubes....but these machines are good enough to justify the risk. I have one disassembled, but it seems there are tons of places to get replacement CCFL's, and like capacitors, seems a lot sell phony/knockoff junk. Where would be the best place to get these tubes? Each panel has 2.
    A couple pics:
    Disassembly was a fun chore!
    Panel Disassembled:
    ...and the tubes:
    Any input would be appreciated!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • diif
    • Feb 2014
    • 6978
    • England
    Re: IBM/Lenovo M90Z CCFL Replacement
    I bought a tube of 10 from Aliexpress. Fixed a couple of 23" with them.
    Nothing special (no name/unbranded) but still as good as the day they were fitted.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Thank you. I just bought a 10-pack for $19USD shipped. Nothing to lose, cheap gamble.
      Team : 49813
      Join in!!
      Team Stats
      • cpt.charlie
        • Sep 2013
        • 270
        • Spain
        Same here, fixed a 32" Sharp TV with 10 CCFL tubes from aliexpress, after 2 months still working fine, the only complaint is about the CCFL contact, thinner an weaker than the original.
        At worst you can try a led conversion kit.
        • heavymachines
          • Mar 2011
          • 1028
          Always got mine at://www.ccflwarehouse.com/ company is located in Omaha, NE. They will also do custom sizes as well.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I have recently started to replace CCFL with LEDs and so far so good....no call backs...
            If you have <24Vdc supplying the Inverter/s for normal operation, then you will need a DC-DC Step-up Module to generate 24Vdc. I use the 2A DC-DC Step-up Module as its input can accept 2-24Vdc and the adjustable output can deliver 9-28Vdc.
            If you can determine the signals on the Inverter section: 1. EN, BL-ON or SW and 2: PWM or P-DIM or ADJ for the LED Driver Board, then you can convert your CCFL/EEFL backlight to a LED backlight. The LED Driver Bd works with 24Vdc only.....You would need 2-4 or even 6 LED strips depending on the size of screen.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Just to follow up this thread.....the replacement tubes finally made it here from China.... What an interesting surgery this was....but a successful one.
              The tubes, packed in PVC tube with chinese writing on it....surprised they didn't think it was a pipe bomb...
              New tube versus old tube. Old tube coating is much darker (top tube).
              New tubes installed.
              Old ones...
              ...and done... Much better!!
              This was a good experience, but a pain in the ass....
              Team : 49813
              Join in!!
              Team Stats
                Do you have the link to that seller at Alliexpress?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Good job. Yes, a little fiddly but worth the effort.
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    • Bulgaria
                    Replacing lamps is pain in the ass. Today I've replaced the CCFL inside the my laptop screen. Contrary to the older IBM Thinkpads in the my Lenovo x200 the LCD matrix was nightmare to disassemble.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      I actually got them from Ebay....I've had not-so-good luck with aliexpress.
                      This is the seller: http://www.ebay.com/sch/meihua361000/m.html?
                      Team : 49813
                      Join in!!
                      Team Stats
                        Thanks, I just want to use the seller that I can trust and pack the lamps well for shipping.
                        • coasterghost
                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                          by coasterghost
                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                          System Hardware:
                          Processor: AMD Ryzen 7 PRO 5850U
                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                          09-08-2025, 10:46 PM
                        • andrhouseolly
                          Lenovo X240 - motherboard replacement for X250, no image.
                          by andrhouseolly
                          Friends. I beg you to help me in this situation.
                          Lenovo X240 with a video problem. Native Intel drivers are not installed,
                          after installation, a black screen. It works with the standard Microsoft driver.
                          Understanding that there are problems with the video core,
                          I ordered a motherboard from Lenovo X250.
                          The laptop turns on, starts up, there is no image on the internal display.
                          The image is output to the external monitor.
                          I ordered another motherboard from Lenovo X250.
                          07-12-2024, 03:02 PM
                        • Grafnus
                          Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                          by Grafnus
                          Hey there,
                          first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                          So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                          Specs:
                          • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                          • CPU, GPU, RAM work fine (not involved in the Problem)
                          So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                          Now I noticed...
                          08-06-2025, 11:54 AM
                        • Nikolai Danylchyk
                          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                          by Nikolai Danylchyk
                          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                          Thanks in advance!...
                          05-08-2025, 06:18 AM
                        • viniciussls
                          Notebook won’t turn on after screen replacement - Lenovo Legion Silm 5 16IRH8_LOQ 15IRH8 Compal ILG10 LA-M542P Rev 1.0
                          by viniciussls
                          Good morning everyone, this is my first post and I apologize in advance if there are any mistakes in the post.
                          I have a Lenovo Legion Slim 5 16IRH8_LOQ with the typical issue of stripes on the screen, but I made the mistake of replacing the screen without physically removing the battery, thinking that just pressing the SW2 button would be enough – it wasn't. The board showed consumption, with LED6301 lit up and PU301 getting very hot. I replaced PU301. Now, the board is not working correctly, but it has no consumption, LED6301 stays on, and I haven't found any other signs of a short...
                          04-02-2025, 01:40 AM
