Lenovo X240 - motherboard replacement for X250, no image.
  • andrhouseolly
    • Dec 2020
    • 28
    • Ukraine
    Friends. I beg you to help me in this situation.
    Lenovo X240 with a video problem. Native Intel drivers are not installed,
    after installation, a black screen. It works with the standard Microsoft driver.
    Understanding that there are problems with the video core,
    I ordered a motherboard from Lenovo X250.
    The laptop turns on, starts up, there is no image on the internal display.
    The image is output to the external monitor.
    I ordered another motherboard from Lenovo X250.
    All motherboards are the same by marking VIUX1 NM-A091 Rev: 1.0,
    they differ only in FRU.
    On LCD CONNECTOR (J10):
    VBL20 - 20v
    VCC3P (VCC3LCD) -3.3v
    PANEL_BKLT_CTR - N/A
    BACKLIGHT_ON - N/A
    Information from BIOS:
    Native board:
    Does not display matrix on external display when cable is connected
    On Lenovo website: X240 Laptop (ThinkPad) - Type 20AL
    Intel Corei5-4210U
    UEFI BIOS Version: GIFT99W (2.49)
    UEFI BIOS Date: 2020-03-17
    Embedded Controller Version: GIHT33W (1.18)
    ME Firmware Version: 9.5.65.3000
    Machine Type Model: 20AL00ETGE
    System Unit Serial Number: PC02XDDP
    System Board Serial Number: L1HF4BV06KE
    VIUX1 NM-A091 Rev:1.0
    FRU: 00HM952
    First X250:
    Outputs to external display when matrix cable is connected
    On Lenovo website: X250 Laptop (ThinkPad) - Type 20CL
    Intel Corei5-5300U
    UEFI BIOS Version: N10ET54W (1.33)
    UEFI BIOS Date: 2018-09-18
    Embedded Controller Version: N10HT17W (1.16)
    ME Firmware Version: 10.0.60.3000
    Machine Type Model: 20CLS08G00
    System Unit Serial Number: PC08ZQ2X
    System Board Serial Number: L1HF5AZ079J
    FRU: 00HT385
    Second X250:
    On Lenovo website: by Machine Type Model is not on Lenovo website
    Intel Corei5-5300U
    UEFI BIOS Version: N10ET57W (1.36)
    UEFI BIOS Date: 2019-05-10
    ME Firmware Version: 10.0.57.3000
    Machine Type Model: 20OPTOORIT
    System Unit Serial Number: 89043544
    System Board Serial Number: L1HF63C031M
    FRU:00HT381​
    Please tell me what the problem is.
    Thank you.
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    First, have you tested this display panel in another ( working ) laptop ?
    Then, do you have a cable for the x250 display ? Chances are good that the cables from the 240 & 250 are different. ( well, supposing your display is good ) .
    • andrhouseolly
      • Dec 2020
      • 28
      • Ukraine
      This matrix is new, works (displays) with the original X240 motherboard (flex cable from X240).
      I thought about the flex cable, but there is no flex cable for X250, besides, the schematic diagrams for X240 and X250 are the same (VIUX1 NM-A091 Rev:1.0 platform).
      The LCD CONNECTOR connector (J10) has no modifications according to the schematic diagram. I checked the complete set (matrix flex cable) on the Lenovo website in the "Details" section
      on X240 Laptop (ThinkPad) - Type 20AL (original board) and on X250 Laptop (ThinkPad) - Type 20CL (one of the purchased boards),
      they have flex cables with the same Part Numbers "eDP, FHD, LUX - Part No 00HM135" in their factory configuration catalog.
      Just in case, I connected the FHD matrix (original - HD), it did not help.
      It is interesting that on the native X240 board the image is output to the matrix, but is not output to the external monitor,
      until you disconnect the matrix, i.e. when the board does not see the matrix - it outputs to the external.
      And in X250 boards, the image is output to the external immediately, even with the matrix connected, but is not output to the matrix.
      It seems that these boards do not see the matrix. But I do not understand where the identification of the presence of the matrix is made.
      I thought on pin18 J10 (EDP_HPD), but I do not see any signal on it (even on a working board).
      • andrhouseolly
        • Dec 2020
        • 28
        • Ukraine
        The problem is solved by replacing the loop. The situation is very confusing due to the fact that with the old loop, the native board (X240) works and displays the image normally, and the two boards (X250) do not display anything on the matrix, although the platforms are identical (VIUX1 NM-A091 Rev:1.0). In addition, on the Lenovo website, in the catalog of factory components, absolutely identical cables (identical part numbers) are specified for all three laptops (by serial numbers). Thanks to rogfanther for the suggestion to replace the loop, I listened and got the right result.
        Thank you all.​
        • rogfanther
          • Jul 2006
          • 458
          • Brazil
          Nice, one more solved. Thanks for informing of the results.
          • checkpointlasem
            • Jul 2025
            • Indonesia
            Thank you all.
            sorry i don't understand what you are talking about replacing the loop. what do you mean the loop? i have same problem
            • andrhouseolly
              • Dec 2020
              • 28
              • Ukraine
              In my case, the solution is described above - the problem was solved by replacing the cable (with the old, native motherboard, the image is output to the matrix, with the new boards there is no image on the matrix).
              • Jilanov
                X240, X250 stays locked after using the patcher
                by Jilanov
                Hello guys,
                I have a problem with 10 pcs X240/X250 which stays locked after autopatcher, i have unlocked already unlocked around 200 pcs this week but these cant be unlocked. When laptop starts with patched bios, it beeps 2 X 5 times.
                Could you support me?
                Attached 1x X240 bios, 1x X250 bios...
                03-19-2023, 10:06 AM
                Lenovo ThinkPad L-X250-SCA-T001 Notebook X Specification for Upgrade or Repair
                This specification for the Lenovo ThinkPad L-X250-SCA-T001 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L-X250-SCA-T001 boardview and L-X250-SCA-T001 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 08:47 AM
                Lenovo ThinkPad X240 Notebook X Specification for Upgrade or Repair
                This specification for the Lenovo ThinkPad X240 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X240 boardview and X240 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                09-06-2024, 08:35 AM
                Lenovo ThinkPad X250 Notebook X Specification for Upgrade or Repair
                This specification for the Lenovo ThinkPad X250 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X250 boardview and X250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                09-06-2024, 06:17 AM
                09-06-2024, 06:14 AM
