Re: Backlight problem on viewSonic VP171b
You may also have bad tubes.
Try the inverter with different tubes, or the tubes with a different inverter.
A little buzzing is normal.
The windings in the Torrids and transformers can vibrate a little.
It's louder because you have it out of the case.
I replaced the two caps shown with Panasonic/ECG "FC" caps (Digikey # P11217-ND). Problem still remains. The screen works for a while, then dies until it cools off for ten minutes or so. I do hear a faint high pitch buzzing before it shuts the monitor off.
I don't know what else to do, other than replace the whole inverter, which I can't seem to find.
Edit: I found the proper model number on the bottom of the inverter;
PLCD2417414Last edited by Starlite528; 01-05-2009, 03:48 PM.Leave a comment:
I also have the VP171b, but my inverter is the "44.58402.002" model.
The caps are Hermei brand, 180 microfarad, 25 volt. I can not find a matching cap at the local stores, including Fry's.
I haven't looked online yet, but am about to. If I can just replace the caps, that's great.
If I can't find the same spec caps, can I substitute something else?
ok. Thanks a lot for your reply. I will check the transistors and the adhesive on the torroids. Then if the inverter always fails, I will replace both the Hermei caps.
Thanks again!
sebastienLeave a comment:
Yes your inverter is shot.
You are lucky enough to have a separate inverter module (the little board with the purple probably Hermei crap caps on it).
I would check the SMT driver transistors near the blue caps for shorts with a DMM. If they check out good.
Replace the 2 Hermeiphroditecaps with good Low ESR caps and try to monitor again also check for any cracked solder joints.
KC stated in another post that the yellow adhesive used on the torroid inductors on that board breaks down and eats at the traces so check that too. Remove the inductors remove all of that yellow crap and repair any broken traces.
Check out this thread:
https://www.badcaps.net/forum/showthread.php?t=5043
In a worse case scenario you could always just buy a new inverter module just replace any bad caps on it off the bat so the your new inverter has a long life.Last edited by Krankshaft; 10-22-2008, 09:45 AM.Leave a comment:
Hello all,
I've got a LCD from ViewSonic. The model is VP171b. It shows the right image for 1 second when I turn it on and then goes black. Powering it off and on again makes the same.
If I direct a flash light on it, I can see what I should see. It's very dark though. From what I've read, it seems to be an inverter problem, am I wrong ?
and reading the posts, it seems that this is usually related to a dead caps.
The caps of my LCD are (according to another post in badcaps)
PSU:
Li-Shin AREX 94V-0
2 Panasonic 16V 1000uF 105oC HFA
1 Panasonic (unknown value because epoxy covered that side, but it is about 1inhc in round, and what I can see says Ce GH)
1 Rubycon XYG 50V 22uF
Backlight Inverter:
Emax 44.61101.001
2 HERMEI 25V 100uF
1 SSA 50V 2.2uF (M)P1 CE 105oC
4 3kV 22J Ceramic caps
2 250V PMS124J Ceramic Caps
Video Board:
Coretronic Corp
Genesis gm5120 chip
13 Taicon 16V 180uF 0304(M) 105oC (VT)
2 Taicon 10V 1000uF 0304(M) 105oC (HF)
2 Taicon 25V 10uF 0302(M) 105oC (PW)
1 Taicon 16V 2200uF 0238(M) 105oC (PW)
1 Taicon 16V 470uF 0246(M) 105oC (VZ)
I'de like to know what would be the most pragmatic solution for trying to identify bad caps and replacing them as I've never tried to repair a LCD. I put some picture of the LCD boards in attachments.
Can you help me ? Thanks a lot in advance, I'd really like to make this screen works again
sebastienTags: None
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM -
by valvashonFor some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...1 Photo -
by eccerr0rIf I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
Next thing is trying to charge the batteries using solar power, but that's another issue ... - Loading...
