Sharp LQ10D368 LED conversion & TTL > LVDS question
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Momaka posted about LED conversion here.
    It got me interested because I have a Sharp LQ10D368 without backlight inverter.
    I could of course buy a cheap inverter, but the LCD is 10 years old so probably the lamps are very worn already...
    I found LED kit below which is a perfect match for it, however being twice as expensive as a whole new panel on eBay is just ridiculous!
    http://www.ebay.com/itm/151920718889
    This thing has been in a lathe which I was called over to fix because it just displayed lines on the screen.
    Turned out to be intermittent connection in the flex cable to the LCD.
    (Customer had already bought a new display but problem remained and that's where I came in).
    It also has what I think is a TTL > LVDS converter module, which is then connected to the mainboard which is an Advantech PCA-6773
    What's odd about this is that in the BIOS for said mainboard are driving options for both LVDS but also 18-bit TTL directly.
    I have ordered the following cable as a test to see if I can just do away with that whole converter board and connect it directly.
    Unfortunately I don't have any mainboards at hand to test with though.
    (For now I've connected up the lathe with an external LCD display temporarily).
    http://www.ebay.com/itm/371160699996
    • 31214
    Re: Sharp LQ10D368 LED conversion & TTL > LVDS question
    maybe you could hook it to one of these.
    http://www.ebay.co.uk/itm/381581274868
    i'm waiting for delivery - i'll do a small review when it arrives.
    i'm hoping to hook it to an 8" panel from an android tablet!
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      That one looks like only LVDS, not TTL.
      But great price though!
      Would love to find a LED conversion at similar rates!
      • lpraderi
        Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
        by lpraderi
        Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
        In some cases to use LVDS screen PCB use converter IC RTD2132/6
        Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
        at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
        Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
        11-25-2023, 09:31 AM
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • gavenb
        Sharp LC-80LE661U 80 inch
        by gavenb
        Hi folks!
        I have a LC-80LE661U that had some interesting issues.
        Initially, it would come on and show the sharp logo and would show normal static before shutting off.
        I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
        11-12-2023, 02:05 PM
      • SONY_E-WASTER
        Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
        by SONY_E-WASTER
        Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
        The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
        then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
        does...
        12-26-2021, 05:46 PM
