Need capacitor values and working voltages - Dell 2408WFPb
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • jasonbay13
    Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
    by jasonbay13
    it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
    PU200
    pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
    pin 8 vreg3 = 0v
    pin 13 en = .2v
    pin 1,6 entrip1,2 = 0v
    b+ and b++ = 19.5v
    +5valw = 0v & 25+ohm to ground
    +3valwp = 0v & 25+ohm to ground
    i cleaned the board up just a little and can get more pics.​
    where should i be looking? thx...
    09-25-2025, 10:54 PM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • Rosen Anastasov
    Dell XPS13 9370 with LA-E671P motherboard - power issues, no 3.3V and 5V always on voltages
    by Rosen Anastasov
    The computer is the one in the subject. Dead. So dead, that no button, no nothing works. Zero signs of it being live until I open it.
    What's verified - the B+ voltage is there at 8.4V.
    Battery is probably dead, cause it was a bit over discharged (to 6V). I forcefully charged it directly on the cell terminals to 3.8V per cell. Now it has voltage on the output connector, but it is 7.1V, not 7.6V. Even when connected to the motherboard it doesn't charge. But will look at that later.
    The +3VALWP and +5VALWP voltages are missing. Traced them to PU500 and PU501....
    08-01-2025, 06:06 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
