Hello everyone my first post here, I have this board in a Samsung lt23b551ew, have been trying to repair with the hep of a friend but we are stuck as we can't find any info on this board, our problem is all the components check out on the hot side of the board but there is no power on the cold side any ideas?
Bn44-00504c
Tags: None
Re: Bn44-00504c
Please ask about this board in the TV section and also:
https://www.badcaps.net/forum/showthread.php?t=39740Never stop learning
Assuming...7 Photos -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by duwaneHi All.
I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to... -
by mferna14Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
- Loading...
