Bn44-00504c
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • duwane
    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
    by duwane
    Hi All.
    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
    10-17-2023, 07:48 PM
  • mferna14
    Apple 820-01958-A logic board stuck on 5V .19amp
    by mferna14
    Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
    02-21-2025, 03:42 PM
