Iiyama Prolite XB2374HDS
  • dedalo101
    • Jun 2016
    • 21
    • Italy
    Hi everyone, I'm from Italy and I first of all I want to apologize for my english which is not good. Please be patient and correct my if you want
    I have a problem with my monitor Iiyama Prolite XB2374HDS.
    After 3 years of work it started to have some problems. Around 1 month ago, after some hours of usage, the monitor started to don't display images on the screen even if the power led was on blu (normal working condition).
    The solution that I found was to unplug the power cable for at least 1 minute and reconnect the plug again; with this simple solution the monitor returned to work as expected.
    Recently the problem is changed. After some hour of work the monitor turns off completely. The previous solution was also applied to this problem and it worked.
    I am here to have some feedback/hints from users of this forum to resolve once and for all this problem.
    I have disassembled the monitor in search of bad capacitors through a quick visual inspection. Unfortunately the capacitors seem good.
    I want also to highlight that the power board uses rubicon capacitors (one of the recommended manufacturer) except for two of them which don't have any manufacturer label and which I cannot recognize.
    Photo Here:
    https://drive.google.com/drive/folde...LjjLF62GZOPTLQ
    The logic board don't use rubicon capacitors but an unknow/unlabeled manufacturer.
    Photo Here:
    https://drive.google.com/drive/folde...Gg&usp=sharing
    My idea is to buy new capacitors for the entire logic board and maybe for the two unknown capacitors on the power board.
    What do you think about my solution? Thanks for the help!
    Re: Iiyama Prolite XB2374HDS
    Can we see the straight shot pictures of the whole top side and the bottom side of the board?
    BTW, the Power LED still stay on blue but no backlights?
    • dedalo101
      • Jun 2016
      • 21
      • Italy
      Actually I have reassembled the monitor so I cannot provide to you these pictures at the moment; If you are interested in the solder status I can assure that they are in perfect conditions on both of the boards. All the components seem in perfect working condition.
      About the power.. no; the problem that I have now is that the power goes away and the monitor turns off by itself after some hours of work (sometimes 3 or 4, other times more); the led turns off completely (no orange stan-by). This is a different problem from what I had 1 or 2 months ago when the backlights goes away and the led passes from blu to orange (stand-by).
      In less words It seems that the initial problem has changed and now it behaves in a different way.
        The reason I want to see the bottom side of the board is so I can trace out the connections for you to test the certain test points on the board, same for the pictures of the whole board. You can also have bad lamp/s.
        • dedalo101
          • Jun 2016
          • 21
          • Italy
          OK.
          I will disassemble the monitor as soon as possible.
            Make sure to show the whole board top and bottom.
            • dedalo101
              • Jun 2016
              • 21
              • Italy
              I did as much as possible photos as requested. Hope that them will be ok.
              If you have any question, please ask.
              Link:
              https://drive.google.com/open?id=0B5...nZFeTkwUFA2bEE
                OK, that white flat cable that goes to the LCD panel is for the LED backlights which I will not be surprised if you have bad LED backlights.
                I will have to trace the bottom side of the board to see how the LED backlights are being driven so I can give you the test points on the board, this may take a while.
                • dedalo101
                  • Jun 2016
                  • 21
                  • Italy
                  OK, take your time and thanks for the support!
                  Yes the white cable goes to the backlight. I haven't highlighted the connector which "drives" the image to the screeen on the logic board. The related cable is not show in the photo.
                  What do you mean with bad backlight? Do you mean that it can be repaired?
                  • dedalo101
                    • Jun 2016
                    • 21
                    • Italy
                    HI,
                    any news?
                    • dedalo101
                      • Jun 2016
                      • 21
                      • Italy
                      News?
                      • boyebaran
                        • Sep 2015
                        • 247
                        • iran
                        first u must check dc voltage supply on back light flat cable connector .you know for supply lighting led need to dc voltage.(flat white cable connect to display)
                        • dedalo101
                          • Jun 2016
                          • 21
                          • Italy
                          I'm sorry but I need more info on how to do the test, I'm a noobie :/
                          I have understood where to do the measure but I don't know how to set the multimeeter and where to put the pins.
                          • boyebaran
                            • Sep 2015
                            • 247
                            • iran
                            thats ok.first we must find circuit diagram .please read part number of power board.(for finding schematic).
                            • dedalo101
                              • Jun 2016
                              • 21
                              • Italy
                              Do you mean the serial number? if yes, here it is:
                              1944504P0289
                              I have also made two more pictures about the backlight cable and connector; these could be more useful.
                              https://drive.google.com/open?id=0B5...V8wVWlEUlYzb1k
                              • dedalo101
                                • Jun 2016
                                • 21
                                • Italy
                                any news?
                                • dedalo101
                                  • Jun 2016
                                  • 21
                                  • Italy
                                  Any news? I really need some info... good or bad doesn't matter.. I mean.. I need to know if is better to buy a new monitor or there are chances to repair it. Lately there aren't any progress or news on what to do or how to preceed with the test, so I can not understand how many real chances I have to repair it. I still cannot stay without a monitor for long.
                                  • mikey5791
                                    • 515
                                    • Malaysia
                                    1)Have you done any off circuit test on components such as diode, transistor ?
                                    2)What sort of test equipment (multimeter,esr meter,etc) you have?
                                    3) Do you know the year of manufacture or how many years in usage of this monitor?
                                    Changing the capacitor most likely will solve 80% of your problem.
                                    • dedalo101
                                      • Jun 2016
                                      • 21
                                      • Italy
                                      Have you read the thread from the first message?
                                      • bernard51
                                        • Feb 2018
                                        • 4
                                        • France
                                        Hello.
                                        I know it's a long time...
                                        Have you solved you problem ?
                                        Perhaps, your problem is similar to the one describe here : https://www.badcaps.net/forum/showthread.php?t=39340
                                        I have this problrem...
                                        • mikey5791
                                          Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                          by mikey5791
                                          Got this working ips led monitor by the brand of
                                          Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                          Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                          09-04-2023, 03:50 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
