Iiyama Prolite XB2374HDS
  • dedalo101
    • Jun 2016
    • 21
    • Italy
    Re: Iiyama Prolite XB2374HDS
    Originally posted by bernard51
    Hello.
    I know it's a long time...
    Have you solved you problem ?
    Perhaps, your problem is similar to the one describe here : https://www.badcaps.net/forum/showthread.php?t=39340
    I have this problrem...
    Hi!
    Yes and no; I mean.. after a lot of search on badcap forum (which doesn't include the link you posted, pretty strange that I haven't found it) and other website around the world, I contacted the service desk in Germany and I explained the issue by highlighting the fact that this is was at 99% caused by a faulty component (novatech chip) which dies after some usage as reported by a lot of users around the world and which regulates the digital ports DVI and HDMI (in fact on my monitor the VGA was working normally) and the monitor OS.
    Due to that "engineering issue" I tried to ask for a "no-cost" replacement for the logic board (I haven't the required equipment to program the novatech chip with the bios I found on a polish forum and to solder the newer on the logic board). Unfortunately we haven't found an agreement and I bought the entire logic board+shipment in italy from Germany.
    The shipment arrived almost immediately and I exchanged it the same day. My monitor is now working perfectly.
    • foreman
      • Apr 2014
      • 8
      • Turkey
      Funny that my viewsonic vx2370 smh did the same thing only vga works now ,but then it is in burning-mode ,which ı cant make it out of this loop because buttons arent working cause I burned the soft key board ,yeah I am the most untalented fixer and patianceless.
      • bernard51
        • Feb 2018
        • France
        I use my ProLite B2475HDS only with the VGA input and I have the problem. I never used the other inputs.
        Can you please tell me, dedalo101, where you bought the board+shipment and what was its price ?
        Thanks.
        • dedalo101
          • Jun 2016
          • 21
          • Italy
          someone asked through google drive to have access to the photo:
          here the new links
          https://drive.google.com/drive/folde...LQ&usp=sharing
          The logic board
          https://drive.google.com/drive/folde...Gg&usp=sharing
          @ moderator
          could you please edit the first message and update the links?
            • 21662
            Originally posted by dedalo101
            @ moderator
            Done
            • dedalo101
              • Jun 2016
              • 21
              • Italy
              #26
              Someone have sent to me a request the access to another folder which contains photos of the main boards.
              Here the links to the main folder on my google drive.
              https://drive.google.com/drive/folde...6A&usp=sharing
              • mikey5791
                Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                by mikey5791
                Got this working ips led monitor by the brand of
                Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                09-04-2023, 03:50 AM
                by momaka
                03-15-2023, 10:17 PM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                by Rick_1234
                Good evening, gentlemen.
                Things I tried
                06-22-2024, 04:44 PM
