CHANGE with LOWER Voltage Solid Caps
  • mikail13
    • Aug 2013
    • 93
    • Turkiye
    my Philips 190X LCD sometimes do not work.
    5 caps blown.
    2x 220uF 25v
    3x 470uF 25v Capxon.
    could i use 470uF 16v and 270uF 16v Solid caps.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: CHANGE with LOWER Voltage Solid Caps
    No always use the same voltage caps.
    • mikail13
      • Aug 2013
      • 93
      • Turkiye
      but mobo manufacturer uses lower solid caps on VRM.
      we can use 560 uF 2.5v solid caps instead of 680uf 4v liqid caps.
        • 31094
        only necause they dont make 2.5v liquid caps
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Unless you know the voltage of the circuit use whats there or if you have one thats above rated voltage of the board use it.
            190X??? 5?, 6?, 7?
            http://elektrotanya.com/philips_190x5.rar/download.html
              • 31094
              220uf 25v polymer
              https://cdn.badcaps-static.com/pdfs/...5fa978066b.pdf
              it's going to be cheaper to use pansonic FR series.
              • mikail13
                • Aug 2013
                • 93
                • Turkiye
                it's philips 190X7FB.
                i used
                one 470uF 16v solid.
                one 270uF 16v solid.
                other's 470 uF 16v nichicon 105 C , and 220uF 25V .
                your links dead.
                  i used
                  your links dead.
                  I have no problem with the links in post #6, the file is too big to be upload to B.C.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    In essence there is no problem with 16v caps there, as small computer monitors use 12v for the inverter. However, only the 5v rail for the logic is regulated in these supplies, and with no load (in standby) the 12v will get up to 14v, sometimes a bit higher.
                    Polymer caps are less tolerant to overvoltage than regular lytics. And their typical failure mode is short, so if your monitor suddenly stops working, you'll know why.
                    A working TV? How boring!
                    • mikail13
                      • Aug 2013
                      • 93
                      • Turkiye
                      monitor is OK now.
                      but top panel line is hot (app. 40-45 C) than low line.
                      i think top CCFL is overheating.
                      why?
                        • 31094
                        if you want to strip it out, you could resolder the pins.
                        • mariushm
                          • May 2011
                          • 3799
                          Don't use capacitors rated for lower voltages on monitor power supplies, especially for the part of the power supply designed for fluorescent bulbs.
                          The voltage on lots of old monitors is usually around 12v, some use bigger voltages, some have fairly unregulated power supply (for example they may go up to around 15v-18v and then stabilize in a few seconds at something like 14v, so it's not safe to use 16v rated capacitors)
                          On motherboards, especially at the VRM circuit near the cpu socket, it's often possible to replace electrolytic capacitors with polymer capacitors rated for lower voltages because you actually know processors work with <1v .. 1.2v. Motherboard manufacturers used multiple electrolytic capacitors in parallel with higher than required capacitance and rated for 6.3v or 10v in order to have a much lower ESR (bigger capacitors often equals lower esr)
                          For this reason, it's possible to use 2.5v or 4v rated polymer capacitors of slightly lower capacitance in the VRM - you know the output voltages are lower than 2.5... 4v always.
                          If you don't know the supposed output, what voltage should be on that capacitor, stick with the capacitance and votage ratings of the old capacitor.
                            by momaka
                            03-12-2025, 03:42 PM
                          • Perry Babin
                            Operating caps well below rated voltage
                            by Perry Babin
                            I think this has been answered but I couldn't find the thread.
                            Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                            So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                            If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                            Or would it require reforming?
                            05-23-2024, 05:43 PM
                            by momaka
                            03-15-2023, 10:17 PM
                          • Adenitz
                            Electronics failing when supplied with lower voltage
                            by Adenitz
                            Hello guys,
                            recently I watched Richard's video on YT (Learn Electronics Repair channel) with an explanation why lower input voltage than rated can also kill electronics components.
                            The vide can be shown here.
                            Now, I would like to learn more and I'm not sure that I understood exactly why this is happening.
                            It is clear to me that PWM chip will keep MOSFTES switched On longer (duty cycle is longer) and that they will dissipate more heat. I think this is not the main reason because MOSFET can probably work switched on for a long time. It is also possible that output...
                            12-26-2022, 12:45 AM
                            Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                            by momaka
                            This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                            Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                            Macron Power Technology Co. LTD.
                            Let’s look at the PSU itself.
                            The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                            06-02-2021, 10:05 PM
