Yet another BenQ FP71G+
  • Joe Black
    eager to learn
    • Sep 2015
    • 173
    • southeastern europe
    I have this BenQ which had classic issue with shorted C5707s.
    So I replaced all 4 C5707s and corresponding capacitors (22k160), and resoldered everything, especially inverter components.
    Now, it has classic 2 seconds to black: shows image, BL shuts off, LED stays green, and I can see image with a flashlight.
    I have 15,8V passing PF 801, and reaching Q805 and Q812, but NOT reaching C5707s.
    The only possible issue I can think of:
    One FU 9024N was shorted (Q805), and since I couldn't grab one, I replaced it with FQU 11P06, so now I have one of each on board (Q805 and Q812)
    (not my board, bud identical)
    stay classy
    • 30977
    Re: Yet another BenQ FP71G+
    maybe the tubes are bad.
    also check the blue ceramic output caps.
    • Joe Black
      eager to learn
      • Sep 2015
      • 173
      Sure thing.
      So, if the tube ignites for the 2 seconds, than shuts down, it still can be bad?
      stay classy
        What resistance do you get on the PF 801? >1 Ohms?
        'I have 15,8V passing PF 801, and reaching Q805 and Q812, but NOT reaching C5707s." So not reaching ALL 4 C5707?
        The Voltage must have reached the C5707 (2 per Oscillator) Royer oscillators setup otherwise you will not get the lamps to even flash on for seconds.
        You need test lamps to help narrowing down the problem.
        https://www.badcaps.net/forum/showthread.php?t=19987
        BTW, if Q805 shorted out, the the Inverter in that section will run at full lamp brightness.
        • Joe Black
          eager to learn
          • Sep 2015
          • 173
          In my case, PF801 is a jumper, I'll post my picture later.
          The Voltage must have reached the C5707 (2 per Oscillator) Royer oscillators setup otherwise you will not get the lamps to even flash on for seconds..
          As usual you are correct. I think voltage gets to C5707s and drops very fast.
          Yes, that is a handy tool. Will make one and post results.
          I thought it fries the C5707 when shorted, since my burned a couple of times.
          Guess something else fried them.
          stay classy
          • Joe Black
            eager to learn
            • Sep 2015
            • 173
            After some playing with BenQ, i found out this:
            If I lower the brightness enough, it will work normally and stay on forever.
            If I put the brightness up (somewhere around 80 out of 100) it shuts down the BL.
            Is this problem with some component not withstanding higher current?
            What measurement could narrow it down?
            stay classy
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              You either have something in the inverter dropping out or one of the wires to the CCFLs is weak and arcs at higher current. I would test the lamps with another inverter if possible.
              A working TV? How boring!
              • retiredcaps
                • Apr 2010
                • 9271
                I have the same problem with this monitor. If I lower the brightness down to 35, it stays on and works indefinitely. If I up the brightness, it goes 2 seconds to black.
                Given it is only a 17 inch monitor and I have several spare, I just use it like so. The amount of effort and since I already ruined/broke a ccfl in a previous attempt, once this monitor dies, it goes to the recycle center. I'll save the power and logic board.
                --- begin sig file ---
                --- end sig file ---
                • Joe Black
                  eager to learn
                  • Sep 2015
                  • 173
                  Totally reasonable. BUT, I just love to repair electronics.
                  If only I knew how to
                  stay classy
                  • seppde
                    Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                    by seppde
                    I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                    ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                    The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                    In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                    02-09-2024, 05:19 AM
                  • AJ847.63e
                    BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                    by AJ847.63e
                    Hi All.
                    Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                    The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                    09-18-2023, 06:42 PM
                  • ChatBTC
                    Benq EX3501R
                    by ChatBTC
                    Hi!
                    I am new to this site, and found it via LLM ChatGPT.
                    I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                    01-24-2025, 08:49 PM
                    BenQ JoyBook S52 S53 Laptop Schematic
                    Quanta ED3...
                    11-01-2024, 02:03 PM
                    BenQ S72 Laptop Schematic
                    Inventec Grasshopper Rev 3.0...
                    11-01-2024, 07:23 AM
