Dell 3008WFP Vertical Line
  • mkfantastico
    • May 2016
    • 4
    Was hoping to get some opinion on this.
    I was thinking of buying a second hand Dell 3008WFP for super cheap (almost spare part money), but am not sure it's a good idea because (a) it's old, and (b) it has a black vertical line as pictured when it's turned on, but it goes away after a while. Does anyone have an opinion as what this might be? Is this a fixable issue (cap/ribbon, etc)? Or is the LCD panel itself going bad?
    If it's potentially fixable I'll probably jump on it, but if it's the beginning of the end, probably makes sense to skip it.
  • mikey5791
    • 514
    • Malaysia
    Re: Dell 3008WFP Vertical Line
    You can try disconnect the ribbon cable which connects to lcd panel.
    Then use an eraser to clean off any dirt/rust from the cable exposed pins and also the pins on the lcd panel side.
    Connect everything back, and hope the black vertical line is gone.
    I have done this with success on an Acer monitor. Hope yours work too.
    Otherwise it is easy to buy a replacement lcd panel.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Panel failure not fixable sorry.
      • mkfantastico
        • May 2016
        • 4
        Thanks for the feedback guys. Given I haven't spend any money on it, it's probably not worth the risk. Cheers.
        • GlenC
          • Dec 2016
          • 5
          Last time I turned on my 3008WFP, the screen went black, then the right half had faint vertical blue and black lines.... Have taken the monitor apart and don't see any bad caps, will replace D22, however I suspect there may be a panel issue.... Any ideas?
          Glen
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • TrueSword88
            Kogan - KALED65XU9220STB - Blue Vertical Line
            by TrueSword88
            Hi all.
            I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
            The line just happens to coincide with the end of COF and start of the next COF (attached).
            The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
            Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
            Hoping to fix...
            05-05-2023, 04:28 PM
          • almarhum
            To fix laptop screen vertical line by working on its EDP cable
            by almarhum
            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
            05-07-2024, 02:12 PM
          • mrsith
            Samsung UE58TU7100K - no picture, vertical line
            by mrsith
            Hi.
            Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
            This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
            Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
            02-07-2023, 11:18 AM
          • bdalkiran
            55EC930V white vertical line appeared (need help)
            by bdalkiran
            Dear All,
            I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
            Please advice how to proceed and what is the...
            01-13-2023, 04:16 PM
