Viewsonic VX1962 noisy when updated
  • geertd
    • Feb 2016
    • 5
    • spain
    I bought this monitor a long time ago. It always worked fine, but last week it started behaving strangely:
    This is a secondary monitor on a two monitor system that runs Linux Fedora 22.
    The primary monitor is connected via HDMI, the secondary one (the viewsonic in question) via DVI cable. Both are connected to the same video card.
    Since a couple of days, the screen works fine as long as the contents shown on the screen are not modified. As soon as its contents are changed (like moving a window or changing its content), it gets noisy for about 2 seconds after the change, than works fine again. The noise shows a pattern of vertical noisy lines over the whole screen. During this time the screen contents remain readable. This only happens on the viewsonic. The primary Samsung does not have this problem.
    To make sure this is not a cable or cable contact issue, I changed the DVI cable and connected the monitor with an analog cable (DSub). This did not improve this noisy behaviour.
    I wonder if this could be a capacitor issue, since I could not find other posts describing the same behaviour as above.... ??
    Regards,
    Geert
    • 31087
    Re: Viewsonic VX1962 noisy when updated
    it probably is a cap, but it could be on the mainboard or panel.
    it sounds like a panel bias voltage is not right.
    • CapLeaker
      Leaking Member
      • 8214
      open it up, have a look and post some pictures.
      • geertd
        • Feb 2016
        • 5
        • spain
        OK, got another little task for the weekend. I first posted my problem in case someone has seen this problem before and would point to something else instead of bad caps...
        Geert
        • geertd
          • Feb 2016
          • 5
          • spain
          So,
          I opened the viewsonic, and did not see anything that points to bad caps. See attached pictures,
          Assembled the monitor again and I still have the same problem, although it looks as if now the screen noise is more horizontal than vertical
          Geert
            • 31087
            you cant see bad caps unless they are large.
            you need an ESR meter.
            although as small caps cost about 15c for decent ones, it's cheaper just to replace any you suspect.
              http://s807.photobucket.com/user/bud...?sort=3&page=1
              Recap the board (including the very small lytic cap in primary side) before it is too late and take out the power MOSFETs that drive the inverter transformer.
              • CapLeaker
                Leaking Member
                • 8214
                a bad cap doesn't have to "look" bad. It can look good and still be bad. So replace them either all, or those that have bad esr.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  As the others said, the caps don't have to look obviously bad to be bad.
                  Moreover, you have CapXon caps on your power supply, which is one of the worst brand. My recommendation is to replace all of the CapXon caps except the very large 400V one (that one rarely causes problems and is usually also pricey).
                  Lastly, post a picture of your video/logic board (the one that attaches to teh power supply board). You may have more bad caps there (that don't necessarily look bad again). Sometimes, the manufacturer will place those small caps next to a hot linear regulator, and they will slowly dry over time and fail without any visible sign whatsoever.
                  • geertd
                    • Feb 2016
                    • 5
                    • spain
                    just ordered new caps. Will post result when replaced
                      by momaka
                      03-15-2023, 10:17 PM
                    • wattage
                      AOC AG493UCX 49-inch monitor - Firmware request
                      by wattage
                      Hello Badcaps Community,
                      The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                      07-13-2025, 04:41 PM
                    • ant3202
                      HP 27es - LED monitor - Monitor Flashing On - Off
                      by ant3202
                      Hi Everyone
                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                      https://www.badcaps.net/forum/troubl...lashing-on-off
                      The monitor is HP 27es LED Monitor
                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                      The monitor will randomly blackout and display no signal and will recover again.
                      Sometimes need to power and off again to restore the display but...
                      03-20-2025, 07:30 PM
                    • Rick_1234
                      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                      by Rick_1234
                      Good evening, gentlemen.
                      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                      https://drive.google.com/file/d/1L6S...ew?usp=sharing
                      Things I tried
                      - Bought a new AC adapter thinking that was the problem but the problem...
                      06-22-2024, 04:44 PM
                      Wise Wing F199 19'' LCD monitor - recapped
                      by momaka
                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                      When I saw the Craigslist post, I wasn't...
                      08-24-2020, 10:58 AM
