BN44-00195A strikes back!
  • steven10
    • Oct 2015
    • 31
    • Italy
    #61
    Re: BN44-00195A strikes back!
    I'm getting steady19V VCC (pin 8) and 0.00V on pin 7(pin out)
      So we can still cannot get the PFC IC to run some how.
      • steven10
        • Oct 2015
        • 31
        • Italy
        #63
        Don't you think 19V is to high as VCC?
        And Why i'm getting an output of 20V when power is ON and 0.00V when power is OFF if the PFC circuit isn't working(always 350V on the big Cap both whit power ON/OFF)?
        350V seems to much too, becouse the voltage between the legs of the big cap should be around 320V when power is OFF and than 380V when power is ON...
          Vcc of 19V is not too high.
          When PS-on is present, it turned on the switched transistor to supply the VCC to the PFC IC and also supplies the VCC to run the 24V power supply, so right now the 24V power supply is running off the 350VDC in stead of close to 400VDC.
          • steven10
            • Oct 2015
            • 31
            • Italy
            #65
            OK,I was expecting the VCC to be around 16V.
            But i'm reading 2.45V between GND and INV pin of the PFC IC(The FAN7530 doesn't work if there's less than 0.45V on the INV pin) so I don't know why it's not working.
              Unless the Zener diode used in the Transistor linear regulator is not 15V. FAN7530 is internal 22V ZENER at VCC pin.
              Read post 45 and later, did you replace the Zener?
              • steven10
                • Oct 2015
                • 31
                • Italy
                #67
                Yes, I did that but I replaced the zener ones again and took some measurements.
                PFC IC FAN7530
                Pin1=~2.10V
                Pin2=0.06V
                Pin3=0.02V
                Pin4=0V
                Pin5=~0.2V
                Pin6=GND
                Pin7=0V
                Pin8=17V
                Big cap = ~390V both with power ON and OFF.
                That's pretty strange cos the PFC circuit is not working at all but I have 390V(fluctuating) on the big cap.
                Only the VCC changes with power OFF(from 17V to 0V), all the other reading stay the same...
                So maybe there's something wrong with the SMPS IC?
                What does PC804s do?
                  It has to be working because you are getting 390VDC, if it is not working you will only get about 330VDC (230VAC * 1.414).
                  • steven10
                    • Oct 2015
                    • 31
                    • Italy
                    #69
                    how it's supposed to be working with those readings?
                    Readings on pins 4 and 7, indicate that the mosfet is open
                    • steven10
                      • Oct 2015
                      • 31
                      • Italy
                      #70
                      I'm also reading 0V on both windings of the LP801 transformer
                        Pin 4 CS (current sense) will in mV high frequency AC KHz).
                        Pin 7 Drive will be high frequency AC KHz range.
                        If you remove the PFC POWER MOSFET then you will not have the 390V, so you see if the PFC is actually working or not.
                          BTW: https://www.badcaps.net/forum/showpo...6&postcount=57
                          That Voltage should be enough to at least cause the backlights to flash on for seconds, so did you check and see if the Inverter board is OK and getting the BL-ON, DIM control signals from the logic board?
                          • steven10
                            • Oct 2015
                            • 31
                            • Italy
                            #73
                            I didn't check the inverter board yet,I just took some measurements on the connector pins using chassis as ground, for now.
                            +24V(x5)=~21V
                            GND(x5)=0V
                            SOS=7.20V
                            ON/OFF=6.15V
                            A_DIM=3.10V
                            EX_PWM=3.80V
                            Backlights remain always off,but i've noticed that I can see images if I put a torch against the screen
                            • steven10
                              • Oct 2015
                              • 31
                              • Italy
                              #74
                              the logic board is definetly good.
                              I'm also able to navigate trough the menu...brightness was set to 100, so I tought reducing the brightness could at least cause the bulbs to flash, but I was wrong
                                +24V(x5)=~21V
                                GND(x5)=0V
                                SOS=7.20V
                                ON/OFF=6.15V
                                A_DIM=3.10V
                                EX_PWM=3.80V
                                I do not know what the SOS pin is, may be some kind of error output pin.
                                The ON/OFF is there but are you sure it is that high?
                                Post good clear picture of the inverter board next.
                                • steven10
                                  • Oct 2015
                                  • 31
                                  • Italy
                                  #76
                                  I removed the power mosfet and still got ~390v,so
                                  I replaced the DMM battery with a brand new one, and now my readings look much more accurate...
                                  I'm actually getting ~300V on the big cap and ~15V on the 24V line.
                                  The ON/OFF shows 5.19V now.
                                  The PFC isn't working so I guess the IC is bad.
                                  I'm going to replace this, ones again,but what I would to know is if there's any way to force the PFC to work,without the IC.
                                    If your line Voltage is 230VAC, then the Voltage on the cap should be = 230V * 1.414 = 325VDC (without PFC). so if you are getting 300vdc on the cap, then your AC must be <230VAC or your meter is still not in calibration.
                                    • Galandil
                                      • Sep 2015
                                      • 19
                                      • Italy
                                      #78
                                      Hello guys, I'm back to the forum since the other 245B that I have at home went dead, usual problems due to the BN44-00195A power board.
                                      I know already all the pieces I need to change, except one: the CY803S lenticolar cap.
                                      I can't remove all the glue that's on it, so the only thing I can read is the value and tolerance: 471K, so it's a 470pF with +/-10% tolerance. What I'm missing is the voltage rating.
                                      I tried to find the schematics of the power board, and one I found shows a completely different value for that cap: 102M 400V (so a 1nF +/-20% 400V). How is this possible?
                                      Moreover, I can't find at the moment a CM812 (12nF 630V) with 3% tolerance, I could buy however one with a 5% tolerance: is it ok?
                                      Any help will be very appreciated, and thanks in advance!
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8688
                                        Without knowing the exact usage of the particular devices, it's hard to tell, photos of the board with the suspect components (and their corresponding schematic) would be helpful.
                                        However usually these low value caps are ceramic and last quite a long time, what makes you think these components are bad?
                                          CY803S is the Y type cap, that cap is use to reduce the EMI to make it pass the EMI test, it is not needed to function. When it is bad it will show leakage resistance. I have never seen this one go bad yet.
                                          CM812 (12nF 630V) with 3% tolerance: that one is 5% (J) not 3%, the important thing about this cap is that it has to be Polypropylene type due to where it is used in the circuit, this one is the command failure that cause low or no 24VDC at the output on the cold side.
                                          Bad glues: https://www.badcaps.net/forum/showth...ight=bad+glues
                                          Pictures provided by shopjimmy.
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • brightest_z
                                            Hot Air Blew Away Resistors Near Bios
                                            by brightest_z
                                            Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                                            Does anyone with more knowledge, and experience than I, know if this is the case?
                                            12-11-2024, 08:34 PM
                                          • jinu_j
                                            LED driver circuit. Burnt Resistors
                                            by jinu_j
                                            Hi Folks
                                            This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
                                            Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
                                            But i have some queries on this circuit
                                            1. The resistors that burnt to crisp...
                                            08-26-2020, 01:24 AM
                                          • repair-it
                                            Pioneer VSX-40 ,Trying to ID these resistors
                                            by repair-it
                                            I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
                                            12-16-2024, 02:08 PM
                                          • BustinCaps
                                            Dell 2007WFP resistors under white silicon blog
                                            by BustinCaps
                                            My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
                                            04-29-2022, 06:19 PM
