BN44-00195A strikes back!
  • Galandil
    • Sep 2015
    • 19
    • Italy
    (For any mod/admin: if you think that a new thread is not appropriate, I apologize in advance and feel free to merge the post in any other BN44-00195A thread ).
    So, I'm a new victim of this power board. I was minding my own business in front of my 245BW, when POP it went, with a nice smell of (probably) burned caps. I started to search infos on the web, and luckily the mighty Google pointed me here on this (great, I have to say) forum.
    I read most of the threads about the power board and its fallacies, and proceeded to crack open the monitor and check the board. As you can see by the photos, I guess the CP801S is dead, so I started to make the list on an online italian shop for all the caps: if I need to change one, why not all. I must rely on an online shop since, where I live, there's no electronic component shop available, so, before completing the order, I'd like to ask some more things to you just to be sure I'll not need another order (and more shipping costs) after the first.
    IIRC, this is the list of all the caps that I need (the link is for reference, I tried to choose Panasonic/Nichicon/Wuerth caps with the same physical sizes as the originals):
    CP801S - 82uF 450V 105° 30x20 -
    CM806/CB809/CB812 - 47uF 50V 105° 6.3x11 - http://www.conrad.it/ce/it/product/4...-1-pz?ref=list
    CM851/CM852 - 1000uF 35V 105° 12x20 - http://www.conrad.it/ce/it/product/4...-1-pz?ref=list
    CB853 - 2200uF 10V 105° 13x20 - http://www.conrad.it/ce/it/product/1...78009?ref=list
    CM857 - 1000uF 10V 105° 10x12 - http://www.conrad.it/ce/it/product/4...-1-pz?ref=list
    CM855 - 470uF 35V 105° 10x16 - http://www.conrad.it/ce/it/product/4...-1-pz?ref=list
    CB804 - 22uF 50V 105° 5x11 - http://www.conrad.it/ce/it/product/4...-1-pz?ref=list
    CB805 - 2.2uF 50V 105° 5x11 - http://www.conrad.it/ce/it/product/4...-1-pz?ref=list
    CP804/CM814 - 10uF 50V 105° 5x11 - http://www.conrad.it/ce/it/product/4...-1-pz?ref=list
    This was the easy part. Now comes the hard, where I need really your help.
    While removing all the goop from the board, two ceramic caps broke, the CM802 (the blue one on the right of the CP801S and south of the two MOSFETs) and the CM809 (to the right of the MOSFETs). Problem is, the goop is on the codes, so I have no idea what kind of caps I have to buy in order to replace them.
    Same goes for various resistors, I can't quite ascertain the right values of them since some color bands aren't very clear under the goop, and moreover I have no idea which is their maximum power dissipation.
    Keep in mind that I have a digital multimeter (with no ESR though) and an old 11W solder, which proved to be ineffective in removing the solder from the PCB (I think I'll get a Basetech ZD-30B kit, which is a 30W solder, I guess it should be enough, but feel free to correct me if I'm wrong ), so far the only resistors that I managed to remove and measure are the RB801 and RB802.
    So, about the resistors:
    RB801 and RB802: it seems that they're both 100k ohm resistors with 5% tolerance; tested them after removing them from the board, got readings of 98.3k and 98.6k
    RB801S: I guess it's a 33 ohm (tested on the board, and that's the reading, 33.2), but I can't understand the tolerance since it has 5 bands (which seems to be orange/orange/black/gold and the fifth I can't understand what color is)
    RM801: from the color, I guess this is a 0.22 ohm 5% (red/red/silver/gold) (I wasn't able to measure it)
    RB808: it should be a 2 ohm 5% resistor (red/black/gold/gold), the tester gave me a 2 value even if measured on board;
    this is what I gathered from the colors and the readings, still have no clue about the power dissipation and with what kind of resistors I should replace them (carbon, metal film, High Power Wirewound, etc.). Any help will be very appreciated.
    Of course I checked the fuses too, and they appear to be both open circuits, so I'll have to buy a couple new too.
    Lastly, as I said before regarding the fact that I'm ordering online, I'd like to know if there's anything else that I can check with the multimeter, in order to add other possible components to the order - so the what to check and how to check (I'm a newbie so I'll need detailed instructions I guess).
    Well, that's it, my wall of text is over, you can see some photos attached to the post, if you need some more photos, ofc feel free to ask.
    Thank you all in advance!
    Re: BN44-00195A strikes back!
    CM802: 2.2nF (0.0022uF) 1KV Ceramic, 5 or 10% will be fine.
    1KV: http://www.digikey.com/product-detai...977-ND/4457545
    I would go with higher Voltage rating:
    http://www.digikey.com/product-detai...183-ND/1021831
    CM809: 47pF 1KV Ceramic, 5 or 10% will be fine. This one is hard to find. EBAY?
    BTW: CM812 (12nF (0.012uF 630V special cap, Blue rectangular) is also know for common failure causing no 24VDC.
    http://www.digikey.com/product-detai...2113-ND/585180
    800V rating:
    http://www.digikey.com/product-detai...256-ND/2179293
    • Galandil
      • Sep 2015
      • 19
      • Italy
      Ty for the info about the ceramic caps. I didn't find them on that store, but apparently a guy on ebay from the UK has both of them with a 2kV rating.
      Fact is, though, I have serious problems in finding the 12nF 630V (800V) 3% cap, I can't find it anywhere except on digikey and mouser (which imply a cost of respectively €18 and €20 to Italy, whereas all the products amount to only €11-12...).
      What can you tell btw regarding the resistors? Are those values correct, and what power rating should I choose?
        Regarding to the resistor values, I will have to dig up those blown up board to look at them.
        The 12nF cap, you can test the capacitance to see if it is still showing the correct capacitance, when this cap goes bad, the capacitance will be way off (less capacitance).
        • Galandil
          • Sep 2015
          • 19
          • Italy
          Regarding the resistors, I've found these as substitutes (all metal film):
          2x100k ohm 1W
          33 ohm 1W
          2 ohm 0.6W
          0.22 ohm 0.6W
          Dunno if the power ratings are ok for each resistor, there're even power resistors for the 0.22 one with a power rating of 2.5W.
          About checking the 12nF cap, I'd have serious problems in doing that, as I said I don't have an ESR meter, I checked the resistance with the meter set to 2M and the value stopped almost instantly at 206 instead of going up indefinitely. Can it be because I tested the cap on board?
            RB801, RB802 = 100K Ohms, 5%, 1W, Flame proof MOX (Metal Oxide).
            RB808 = 2 Ohms, 5%, 1W, Flame proof MOX (Metal Oxide).
            RB801S = 33 Ohms, 5%, 1W, Flame proof MOX (Metal Oxide).
            Per your readings, they are OK.
            RM801 = 0.22 Ohms, 5%, 1W, Fusible Resistor Flame proof MOX (Metal Oxide).
            Notes: if the resistance tested OK then no need to replace them.
            • Galandil
              • Sep 2015
              • 19
              • Italy
              From that shop, there're no MOX 0.22 resistor with 1W, the only one has a power rating of 0.6W.
              There's a 0.22 resistor with a power rating of 2.5W though, it's a wirewound resistor, this is the specs sheet:
              Which one should I get?
                It has to be fusible flame proof type and correct Wattage due to safety requirement. You do want the monitor to catch fire when there is problem.
                • Galandil
                  • Sep 2015
                  • 19
                  • Italy
                  Then I need to de-solder it in order to check if the actual one is ok. From the photo, it seems that it hasn't blown/taken fire, can you confirm pls?
                  However, since all the resistors measured ok, I guess I can skip them.
                  Now the only problem remains with the 12nF, what happens if it's shot and I proceed to mount all the other caps and turn on the power board? Is there any risk that something else will break again, or it will just not function? If it's the latter, I can take the risk and order and mount all the other pieces.
                    "RM801: from the color, I guess this is a 0.22 ohm 5% (red/red/silver/gold) (I wasn't able to measure it)"
                    So the 0.22 Ohms fusible resistor is OK then? I thought you cannot measure it. When those blue disc caps shorted out, they will take out that fusible resistor with it.
                    The fusible resistor is used for feed the Voltage to run the 24V POWER SUPPLY, the two Power MOSFETs QM802, QM803, and the caps CM802, CM809, CM812 are part of the circuits for driving the transformer TM801S for the 24V.
                    "Now the only problem remains with the 12nF, what happens if it's shot"
                    You need to check its capacitance and also check the resistance to see if it has leakage resistance, you need to remove it to do the test.
                    You should also check the resistance between Source and Drain pin of Power MOSFETs QM802, QM803 to make sure they do not show low resistance readings, you can test them on board, if they do show low resistance then you need to remove them off the board and test them again.
                    • Galandil
                      • Sep 2015
                      • 19
                      • Italy
                      Ok, this evening I removed the .22 resistor from the board, measured it and... nothing, it's an open circuit so I guess it's blown.
                      How am I supposed to check the capacitance without an ESR tester?
                      I removed the cap and tested for resistance: open circuit always. IIRC caps should show a raising resistance with the tester in ohm measurement mode. Should I try some other test?
                      Don't those 2 MOSFETs have a diode between source and drain? I checked for it with the diode test mode on the meter, and the diode was working good in both FETs, open circuit when inversely polarized, and a drop of .587V for both when directly polarized. Or did you mean some other test?
                      TY for the patience though, and please remember that I know very little on the topic.
                        "How am I supposed to check the capacitance without an ESR tester?" You are testing the capacitance of that cap not ESR.
                        The MOSFETs when they failed it will show very low resistance between S and D pins so yours are OK then.
                        • Galandil
                          • Sep 2015
                          • 19
                          • Italy
                          But my meter doesn't have a capacitance mode.
                          This is my meter: (and atm I can't even check currents, since I just discovered that the internal fuse is shot damnit).
                            You can try replacing the damaged parts first and see if you do have 24VDC or not, if not then that 12nF will have to be tested for capacitance some how.
                            • Galandil
                              • Sep 2015
                              • 19
                              • Italy
                              Ok, I managed to find a shop that sells all the capacitors I need (including the ceramic ones and the 12nF 800V).
                              Now, I'm almost done with the pieces needed, except for one: the dreaded R22 1W 5% fusible resistor. Apparently, it's almost impossible to find one such resistor, in all italian online big shops I couldn't find it, Mouser doesn't have it, Digikey doesn't display the price since it's a non-stock (and apparently you need to order a large quantity, 2000 pieces), etc.
                              The only available resistor that I found available on an online shop is this:
                              The only difference is the tolerance, 10% instead of 5%.
                              Can I go with it the same?
                                10% or 5% is not critical. That should be fine.
                                • Galandil
                                  • Sep 2015
                                  • 19
                                  • Italy
                                  Ok, thanks, just one last thing: I just want to be sure and buy the 2 MOSFETs as a replacement in case something goes wrong or they'll break in the future.
                                  The code is FQPF9N50C, and I can see that this product is discontinued by Fairchild, now they sell the FQPF9N50CF. Is it ok in case to use the new one?
                                  The specs are these:
                                  C - https://cdn.badcaps-static.com/pdfs/...73d52af526.pdf
                                  CF - https://cdn.badcaps-static.com/pdfs/...9d1150d5cf.pdf
                                    The CF has Fast recovery Body diode, the CF should be fine to use.
                                    • Galandil
                                      • Sep 2015
                                      • 19
                                      • Italy
                                      Well thanks for all the help, budm. I'll put the orders and I'll report back as soon I finish getting back (in working state, I hope) the monitor.
                                      • Galandil
                                        • Sep 2015
                                        • 19
                                        • Italy
                                        Update.
                                        Today I received all the pieces finally, and mounted them. Operation 245B+ successful, now it's working again.
                                        Thanks budm for all the advices.
                                        Just a not-so-important question: for some reason, now the blue standby led of the monitor is a lot dimmer than before. Can it depend on the fact that some pieces are not exactly the same as before?
                                        Namely, the fusible resistor with a tolerance of 10%, the 12nF cap @800V instead of 630V, and the 47pf and 2.2nF ceramic caps @2kV instead of 1kV.
                                        I'm just curious about it, all the other caps/resistors are exactly the same as the ones before.
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • brightest_z
                                          Hot Air Blew Away Resistors Near Bios
                                          by brightest_z
                                          Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                                          Does anyone with more knowledge, and experience than I, know if this is the case?
                                          12-11-2024, 08:34 PM
                                        • jinu_j
                                          LED driver circuit. Burnt Resistors
                                          by jinu_j
                                          Hi Folks
                                          This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
                                          Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
                                          But i have some queries on this circuit
                                          1. The resistors that burnt to crisp...
                                          08-26-2020, 01:24 AM
                                        • repair-it
                                          Pioneer VSX-40 ,Trying to ID these resistors
                                          by repair-it
                                          I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
                                          12-16-2024, 02:08 PM
                                        • BustinCaps
                                          Dell 2007WFP resistors under white silicon blog
                                          by BustinCaps
                                          My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
                                          04-29-2022, 06:19 PM
