BN44-00195A strikes back!
  • Galandil
    • Sep 2015
    • 19
    • Italy
    #81
    Re: BN44-00195A strikes back!
    Thank you for the answer, Budm.
    Originally posted by budm
    CY803S is the Y type cap, that cap is use to reduce the EMI to make it pass the EMI test, it is not needed to function. When it is bad it will show leakage resistance. I have never seen this one go bad yet.
    So this means that I can even remove this cap without issues.
    CM812 (12nF 630V) with 3% tolerance: that one is 5% (J) not 3%, the important thing about this cap is that it has to be Polypropylene type due to where it is used in the circuit, this one is the command failure that cause low or no 24VDC at the output on the cold side.
    Then this should work fine: http://it.farnell.com/epcos/b32671l0...ale/dp/2468980
    I'm only concerned a little about the length of the terminals, they seem to be 5mm long, and the distance between them is 10mm whereas on the board the distance between the holes is about 14mm, but I have no other choice at the moment (there's another model by Panasonic with long terminals, but I'd have to pay for one of them an additional €22 just for the shipping from the USA, a little bit too much for my tastes).
      Just solder some bare wires to the legs, just do not bend the legs.
      • TinkerTron
        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
        by TinkerTron
        Hey everyone,
        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
        Instead, here's what's been bugging me so far:
        The schematic...
        03-06-2025, 02:03 PM
      • brightest_z
        Hot Air Blew Away Resistors Near Bios
        by brightest_z
        Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
        Does anyone with more knowledge, and experience than I, know if this is the case?
        12-11-2024, 08:34 PM
      • jinu_j
        LED driver circuit. Burnt Resistors
        by jinu_j
        Hi Folks
        This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
        Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
        But i have some queries on this circuit
        1. The resistors that burnt to crisp...
        08-26-2020, 01:24 AM
      • repair-it
        Pioneer VSX-40 ,Trying to ID these resistors
        by repair-it
        I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
        12-16-2024, 02:08 PM
      • BustinCaps
        Dell 2007WFP resistors under white silicon blog
        by BustinCaps
        My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
        04-29-2022, 06:19 PM
