Help - how to test an inverter transformer
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Hi Guys,
    I have been wondering how could I learn to test Inverter transformers and any other sort of transformers. I have been googling around and tried to understand the below webpage:
    http://www.jestineyong.com/test-lcd-...r-transformer/
    Can anyone please assist and teach me how to test them please?
    Thanks,
    Matt
    • 31025
    Re: Help - how to test an inverter transformer
    http://members.ozemail.com.au/~bobpar/fbt.htm
    i use this to test transformers.
    the pdf has the schematics to make one.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      What do you not understand?
      • matthmal
        • Nov 2012
        • 306
        • Malta
        Not sure how could i do that.... is the below similar?
        http://www.ebay.co.uk/itm/Philips-Fl...item3f4a76b42b
        • matthmal
          • Nov 2012
          • 306
          • Malta
          Can't really understand how to test it and what should be the results.... I understood that an ohm test should take place but i do not know what should the results be and which joints should i test
            • 31025
            nothing to do with it.
              To do the Ohms test, you will need to get the P/N to find the pinout, you can go to LCDPARTS.NET to see if the transformer you are trying to test is on the site, for example:
              http://lcdparts.net/T.aspx
              Just hit the buy now and the transformer spec will come up.
              http://lcdparts.net/TransformerDetai...ProductID=2732
              You can also remove the transformer to see how the windings are arrange.
              If you have more than one transformer on the board then you can compare the resistance reading. When you work on many of them you will know how the transformer windings are arranged.
              BTW, are you asking about inverter transformer for LCD TV or Flyback transformer for CRT.
              • matthmal
                • Nov 2012
                • 306
                • Malta
                Thanks will try it out and will let you know.
                May I ask you what you think of this:
                http://www.ebay.co.uk/itm/AnaTek-Blu...item2a2ea6e1dd
                I am asking about LCD and any other sort of transformer which you can find in a monitor, tv and electronic devices.
                  I never use one of those, I use my SENCORE LC75.
                  http://www.ebay.co.uk/itm/Sencore-LC...item2358eeb120
                  • matthmal
                    • Nov 2012
                    • 306
                    • Malta
                    That is surely much better but even more expensive. So the one that i quoted isn't good?
                      • 31025
                      each tool has it's own purpose.
                      the blue ringer is just for testing coils / transformers.
                      an LC(R??) meter is also for checking capacitors - it also gives real numbers instead of just a bar of leds.
                      you get what you pay for.
                      • matthmal
                        • Nov 2012
                        • 306
                        • Malta
                        May i know which is the secondary and primary windings of an inverter transformer pls? Which is the winding that I am supposed to check?
                          • 31025
                          check both.
                          the primary is the one the power goes into and usually looks smaller if you can see it.
                          the secondary is the output to the tube(s)
                          most problems are on the secondary side,
                          but it's worth checking there is no conection between the primary and secondary.
                            Go here and look at the transformers to see what typical windings for the inverter transformers are (the secondary side high Voltage )winding will use very small wires compared to the primary winding).
                            Click on the 'BUY NOW' button to see the spec and the pinouts.
                            For example:
                            http://lcdparts.net/TransformerDetai...ProductID=2727
                            • fzabkar
                              • Mar 2009
                              • 772
                              For example:
                              Thanks for the information.
                              I notice that LCDparts want $22 for the transformer alone, whereas shopjimmy are selling an entire 4H.V0708.321 inverter (which uses 6 of those transformers) for $10.
                              http://www.shopjimmy.com/auo-19-2600...t-inverter.htm
                                I only use LCDPARTS.NET for ref info only (I used to buy from them because they are close by in S.F), their prices are way too high.
                                • matthmal
                                  • Nov 2012
                                  • 306
                                  • Malta
                                  For example:
                                  Thanks for your reply. I can't seem to find the transformers that I want on that website though. Can I do something else please?
                                  Thanks,
                                  Matt
                                    Thanks,
                                    Matt
                                    But so far you have not given us any information or the pictures of the transformer you are trying get or test. You gave the link in post 4 for the Flyback transformer for the CRT.
                                    • matthmal
                                      • Nov 2012
                                      • 306
                                      • Malta
                                      check both.
                                      Thanks for your reply. I came through the attached... is that the way that the windings need to be checked?
                                      Thanks,
                                      Matt
                                        How about the pictures of the top side of the board? and also the whole board both sides.
                                        What is the make and model of this product you are working on? The more information we get the more we can help.
                                        It looks to be correct as you have marked for the High Voltage secondary winding.
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
                                        • vampy999
                                          how to test lcd inverter transformer
                                          by vampy999
                                          i found this very helpful.
                                          https://jestineyong.com/test-lcd-inverter-transformer/
                                          02-28-2021, 07:52 PM
                                        • chth96
                                          How Can I test PWM DM0365R?
                                          by chth96
                                          Hello
                                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                          06-18-2025, 04:14 PM
                                        • signal.quest
                                          Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                                          by signal.quest
                                          I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                                          I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                                          09-30-2024, 11:21 PM
                                        • amelbye
                                          is it ok to replace a dual output transformer with two single output transformers?
                                          by amelbye
                                          Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
                                          Now that's a challenge - luckily...
                                          08-21-2020, 08:51 AM
