Confused cap values during removal- best fix?
  • imcurious2
    • Feb 2008
    Re: Confused cap values during removal- best fix?
    Originally posted by brockklich
    I am attempting to repair a power supply for an LCD display. It failed to power on and there were 6 bulging caps that I feel confident are the problem.
    4 of the 6 were in a row close together. I removed them all, without realizing that they were different values. Now I am not sure which values go into which place on the PCB. 2 were 470 uf / 25v and 2 were 1000 uf/ 10v. They all four appear identical, other than the markings.
    I am trying to figure out my best plan. I cant find any info online about this particular PCB (TDK- model XAD819AR). I have no problem with experimenting with different combinations, but I dont know enough about how they work to know what to avoid. I understand I should never subsitute a lower voltage cap for a higher voltage one, but that the reverse is not true. How about the uf rating though? Could I safely install 1000uf 25 V caps in all four slots without (likely) destroying something else? Would the higher uf rating cause other problems either immediately or later on?
    Is there another approach someone could suggest?
    Thank you for any guidance.
    I have that board in my hand with the same cap problem. The two caps, closest to the TDK label end are the 470 and the two closest to the 8 pin "push on" interface are the 1000.
    • dufflespank
      • Aug 2008
      Hi! I found this post through google.
      Yesterday I pulled a Princeton monitor out of a dumpster and decided that I would try to nurse it back to health. When I plugged it into the wall, it made a steady a clicking noise (came from the two small internal speakers), and when the monitor was unplugged, the clicking noise persisted but diminished in frequency. The monitor never actually powered on. This led me to believe that it was a power supply problem.
      I pulled the whole thing apart and pulled the power supply PCB out. The model number matches the one mentioned above in this post (I'm sure its the same monitor). The 6 large capacitors on the board do appear to be "bulging", i.e. they are not flat on top. I think I will replace them and hope for the best.
      My question is, should the clicking sound indicate a different problem? I don't want to fix the wrong problem.
      Thanks!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        just recap it.should be fine then.
        • i4004
          • Oct 2006
          • 2029
          clicking noise from psu can mean it's overloaded, ie short-circuit on one of the outputs, but clicking on speaker shouldn't be that, so yeah, try recap.
          • Krankshaft
            • Jan 2007
            • 2328
            It could be that the power supply is cycling on and off rapidly due to the bad caps and the onboard speaker amplifier is outputting popping noises to the speakers. Since its supply voltage is being given to it and taken away when the PSU shuts down.
            Similar to the noise heard when you turn an amplifier on or off.
            Just replace the caps you'd be suprised how many times a recap will be all the monitor needs.
            • dufflespank
              • Aug 2008
              #26
              Recapped, monitor works perfectly. So essentially, since the monitor was dumpstered, I basically paid seven dollars for it. Fuck yeah!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Being handy with soldering iron has it's benefits!
                Mann-Made Global Warming.
                - Dr Seuss
                • Galdor
                  • Aug 2008
                  #28
                  Bad caps but replacing them didn't fix the power supply
                  Hi, I had the same problem with bad caps on this power supply board.
                  I replaced all of the bad caps with new ones of the correct specs.
                  My problem is that the display still won't power on and I think there is still an issue with my power supply. If I take a reading on the voltage output pins on the 5V side it holds at about 4.8 to 4.9 volts which as far as I know should be fine. On the 12V side however it jumps all over from 8 on up to 11 volts. I am hoping that someone here might have an idea as to why my 12V side is not holding at 12 volts or thereabouts. Any help would be much appreciated.
                  Thanks!
                  • DannyBoodmannTDLemon1900
                    • Jan 2009
                    • 3
                    #29
                    Just thought I'd add some details and tie it to a monitor model so perhaps others can find this page via a forum search, Google, etc. This was the only legitimate Google result I found concerning this TDK board. Thanks to the op and those that have added to this thread.
                    I discovered the same TDK XAD819AR \ EA0219X board in a friends Princeton VL1919 that he wanted me to take a crack at fixing. These were sold through Costo about three years ago give or take. Symptoms were a blinking display with a synchronized clicking through the built in laptop style speakers on the back on the case. The backlight would occasionally flash on for a moment.
                    This board is both the power supply and the CCFL inverter. On my board the same four CapXon caps, the 470uF and the 1000uF were bad. Three swollen and the fourth had burst out on the bottom which I hadn't noticed until I dropped it out of the board. The two CapXon 220uF in the center of the board appeared ok, however I did notice that a couple of caps not mentioned in this thread either appeared bad or on the way out. There are another three CapXon inside of the "corral" made by the heatsink [C57-C59-C62], C62 appeared swollen and C59 didn't look "quite right". There is yet another little guy [C8] next to the transformer that looked ok but also made by CapXon.
                    I opted to replace all ten caps on the board made by CapXon (green\gold stripe) and recommend if you tackle the job to do this as well. At this point in the thread you've probably already decided to change out the previously mentioned six caps and there's only another four. As most of us will be already paying $5-7 for shipping for under a pound you might consider tacking on the extra <$2 of caps. Not sure why I did, but I left the only non-CapXon radial cap [next to C8] on the board. I looked it up later but I had already placed my order so it stayed on the board. If I recall it was a 47uF 50V, it can be seen but is not marked on the photo.
                    A word of caution, at least six of the caps have either a surface mount cap or resistor soldered near their leads on the solder side of the board. A couple of them are very close. When you're (de)soldering be careful you don't splash a solder short or knock one of those little bad boys off. I recommend doing one leg of a cap and then moving to another cap, allowing that part of the board (and the smc) to cool before coming back for the second leg. I managed to do just fine with my hugely tipped RS squeeze-bulb desoldering iron. Personally, I wouldn't try wicking those, but that's me.
                    The cathode(-) side of the caps are marked on the board with a line through the circle's edge and have a square solder pad on the solder side of the board.
                    The OEM caps are rated to 105ÂşC, be certain to check this value if your replacement choice is categorized as "general purpose" as many are only rated to 85ÂşC.
                    I know most here probably don't need those last bits of advice, but some reading this will be n00bs as we all once were. n00bs are advised to read the faqs and other stickys in the forum, 99% of your questions will be answered.
                    I would have shot the photo with the OEM caps in place but I had to desolder three of them because I couldn't see their specs when they were onboard. When one's soldering and on a roll ...
                    Here are the values along with the current (01\2009) Panasonic FM Series part numbers ....
                    C101 220uf 25v 105ÂşC - EEU-FM1E221
                    C102 220uf 25v 105ÂşC - EEU-FM1E221
                    C51 470uf 25v 105ÂşC - EEU-FM1E471
                    C52 470uF 25v 105ÂşC - EEU-FM1E471
                    C54 1000uf 10v 105ÂşC - EEU-FM1A102
                    C56 1000uF 10v 105ÂşC - EEU-FM1A102
                    C8 4.7uF 50v 105ÂşC - EEU-FC1H4R7 <-- FC Series - FM n/a
                    C57 100uF 25v 105ÂşC - EEU-FM1E101
                    C59 100uf 10v 105ÂşC - EEU-FM1A101
                    C62 100uF 25v 105ÂşC - EEU-FM1E101
                    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." ~ Benjamin Franklin (1706-1790) ~
                      • Jan 2009
                      • 3
                      #30
                      Actually, thats not the only radial left. There's the bigger TAICON as well, I was reffering to the small radial just above C8 in the photo.
                      • eMuNiX
                        • Jun 2009
                        #31
                        So glad I found this thread. I have a Hanns-G HN198D monitor just out of warranty and it has started doing the same clicking problem, does power up after about 15 minutes though. Taking the monitor apart I see that I have the same TDK PSU/inverter board so I have ordered the new caps and will be replacing them early next week. Will report back if I am successful or not.
                        • eMuNiX
                          • Jun 2009
                          #32
                          Replacement caps delivered, fitted and screen is working perfectly again. Thanks to this thread
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Congratulations man.
                            • ASUS ROG Maximus IX Code
                            • Intel Core i5-7600K 3.8GHz
                            • Windows 10 Pro x64
                            • GeForce GT1050
                            • ort11
                              #34
                              Yet another success for TDK XAD819AR Hanns G Model HN199D. Symptoms where Green Light Flash and then very small flash. Would display after awhile (10 mins, etc).
                              Replacing the caps with standard 85 Degree worked and sub 4.7uf 50V with 10uf 50V seemed to work fine. Will report back if it fails for any reason. Display was about 3 years old.
                              • vienet
                                #35
                                And another success for this TDK XAD819AR Hanns G Modell HC194DP.
                                When we want the screen switch on - there was a picture for 2 seconds, then the screen switch off. I thaught there is a failure with the transformers, then I found this forum.
                                Thank you !
                                I have changed C51 and C52 - I have some found in my waste-box :-)
                                We have still 4 of this screens running here - since 2006 - and I hope with some new caps - they will work for another 4 years !!! (or longer..)
                                Best regards, Heiko - Germany
                                • guildwebmaster
                                  • Oct 2010
                                  #36
                                  Hi everyone - I have a soldering Iron and I think I know which end is the hot bit.. does that sum up my soldering ability.. joke - I actually did 6 months in a factory - 2 weeks of which I spent tinning either ends of 1inch wires..
                                  Been experiencing the flickering on and off on my HANNSG monitor for about 3 weeks now - this morning took 30 mins to get 'warmed up' so I was so glad to spot this thread on a routine search.
                                  Maplins locally sell these caps for 18p - 42p each so I'm dropping in there after work
                                  Many thanks to all who posted and contributed to this.
                                  Born from the earth - burnt at the fingers
                                  • Chyenne
                                    • May 2011
                                    • 14
                                    #37
                                    Another Hanns-G HN198D saved by replacing nine caps, all except the biggest, six of which were obviously bloated.
                                    Upon turning on: clicking noise, solid led, no reaction on the display and no possibility to turn off (except cutting power).
                                    Thanks badcaps community.
                                    • Tecc
                                      • Nov 2019
                                      10 years on, let me also thank Danny for this. Just repaired 2 Hanns-G HC194DP's with this help. Also swapped out all the CapXon caps and they work perfectly again.
                                      These monitors have manufacturing dates of 2006, so 13 years old. They were doing to repeat clicking fail-to-power-on thing for the last year or so, at first a nuisance then slowly getting worse, until one died outright.
                                      I measured all the cap values as I pulled them out. The majority were down to approx 1/2 the spec value, a few were down to 1/3rd.
                                      Thanks again for the save!
                                      • proxneo
                                        Recapping Sony ICF-SW55 - verifying cap values
                                        by proxneo
                                        Dear reader
                                        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                        At the moment, I have selected replacements based on the following list of values:
                                        3 x 470uF 10VDC
                                        3 x 4.7uF 35VDC
                                        4 x 47uF 50VDC
                                        8 x 22uF 6.3 VDC
                                        1 x 220uF 6.3VDC
                                        5 x 100uF 6.3VDC
                                        Which...
                                        06-21-2023, 12:38 AM
                                      • TimScrawn
                                        MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
                                        by TimScrawn
                                        Hi there,
                                        This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
                                        I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
                                        06-23-2024, 09:41 AM
                                      • rashidjafar
                                        Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                                        by rashidjafar
                                        I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                                        Values for :-
                                        PC43 : Capacitor [3x1.5mm]
                                        PL7 : Inductor [2x1mm]
                                        PC39 : Capacitor [1x0.5mm]
                                        Any ideas would be appreciated.
                                        I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                                        08-07-2025, 05:10 PM
                                      • Kobok
                                        Different (lower) resistor values on PCB?
                                        by Kobok
                                        Dear Alls,
                                        For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                                        09-19-2022, 07:30 AM
                                      • skdsp
                                        Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
                                        by skdsp
                                        I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
                                        Attached is the photo.
                                        Thank you!
                                        09-27-2025, 09:05 PM
