DELL P2210 - SMPS +5V reads ~+3.5V
  • sansanda
    • Feb 2021
    • Spain
    #41
    Re: DELL P2210 - SMPS +5V reads ~+3.5V
    I reply myself and FYI.
    Finally, In my case I've found the D854 shorted. As mentioned fzabkar I've replaced the pair of diodes.
    Thanks,
    David.
    • torentino
      • Feb 2014
      • 22
      • Slovenia
      #42
      Hello, sorry for kidnapping this thread.
      I have a problem at logic board, no supply to LCD panel, I found the smd Q101 component marked N58A shorted, anybody knows, what is this?
      regards
      • lotas
        • Jan 2016
        • 4755
        • Russia
        #43
        regards
        Transistor in which case, photo can be seen?
        • torentino
          • Feb 2014
          • 22
          • Slovenia
          #44
          transistor, most likely mosfet, SOT23, there are markings on the board near the component G,D,S.
          • lotas
            • Jan 2016
            • 4755
            • Russia
            #45
            hello,
            transistor, most likely mosfet, sot23, there are markings on the board near the component g,d,s.
            ap2305gn
            • torentino
              • Feb 2014
              • 22
              • Slovenia
              #46
              Hello, Lotas,
              thank you very much, now I am on the hunt for a little bastard.
              regards
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • waakye
                Dell XPS 13 9370 no power USB amp meter reads 5V , 0.11A
                by waakye
                Hello fellow bad caps members,
                I have a Dell XPS 13 9730 that a picked up today. The seller claimed that it stops working all of a sudden. The ammeter reads 5V, 0.11A.
                Could some help me out.
                Thanks.
                08-24-2024, 10:26 PM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
                Dell Thunderbolt Firmware
                by SMDFlea
                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                The SKU is in brackets (****)
                EDIT: NVM65...
                01-26-2025, 06:22 AM
