Lenovo li2341twf Monitor - No Power
Re: Lenovo li2341twf Monitor - No Power
If the shorts is n longer there without the cap, then you can power up the board for testing for now.
C702 is a capacitor not a resistor.Last edited by budm; 08-19-2015, 11:09 AM.Never stop learning
You will remove C702, and then you will take the resistance reading bewteen the two solder pads on the board where C702 used to be connected to to see if the low resistance is still exist on the board.
Okay. I desoldered C702 and I still get 2.6-2.8 resistance between those solder pads.Comment
Since that cap is more likely to be the Filter cap for VCC of that IC, unless the there is anything else that are connected in parallel with that C702, then the only left will be that IC is shorted.Never stop learning
So what are my options at this point? Am I stuck because there is no way for me to get a replacement IC? I would love to keep pursuing this repair in anyway possible.Comment
Well, we need the spec of the IC to see which pin is the VCC pin, or you can remove the IC and replace it.
http://nl.aliexpress.com/store/produ...toreId=1771244
or try EBAY.Last edited by budm; 08-19-2015, 01:52 PM.Never stop learning
or try EBAY.
Is there anyway to "guess and check" for the VCC pin? Can I just replace it with the IC with the one in the link you provided? or will that not work because it is not the same part number?Comment
I know it has been a little while but did you ever get the answer to fix the problem?Comment
Unfortunately not. I probably still have the disassembled monitor laying around somewhere. I think I ended up desoldering something poorly, probably rendering whatever component useless, became too busy, forgot where I left off and gave up.
Sorry :/Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by Mita99Hi,
Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no... -
by Dr.dI have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets... - Loading...
