Lenovo li2341twf Monitor - No Power
  • mikey32230
    • Jun 2013
    • 19
    Re: Lenovo li2341twf Monitor - No Power
    Originally posted by budm
    The failure mode of the MLCC (Multi Layer ceramic Capacitor) type capacitor is shorted circuit, so try removing that cap and see if the low resistance will go away
    Okay, so just so I understand correctly.
    I am desoldering C702 and then... testing its resistance out of circuit?
    or am I powering the switchboard without the resistor in circuit?
      You will remove C702, and then you will take the resistance reading bewteen the two solder pads on the board where C702 used to be connected to to see if the low resistance is still exist on the board.
      If the shorts is n longer there without the cap, then you can power up the board for testing for now.
      C702 is a capacitor not a resistor.
      • mikey32230
        • Jun 2013
        • 19
        Sorry, I wasn't thinking when I said that C702 was a resistor.
        Okay. I desoldered C702 and I still get 2.6-2.8 resistance between those solder pads.
          Since that cap is more likely to be the Filter cap for VCC of that IC, unless the there is anything else that are connected in parallel with that C702, then the only left will be that IC is shorted.
          • mikey32230
            • Jun 2013
            • 19
            So what are my options at this point? Am I stuck because there is no way for me to get a replacement IC? I would love to keep pursuing this repair in anyway possible.
              Well, we need the spec of the IC to see which pin is the VCC pin, or you can remove the IC and replace it.
              http://nl.aliexpress.com/store/produ...toreId=1771244
              or try EBAY.
              • mikey32230
                • Jun 2013
                • 19
                or try EBAY.
                So I have searched pretty thoroughly and I cannot find anything close to that IC part number. The link you listed is the closest I have seen.
                Is there anyway to "guess and check" for the VCC pin? Can I just replace it with the IC with the one in the link you provided? or will that not work because it is not the same part number?
                • mikey32230
                  • Jun 2013
                  • 19
                  Originally posted by Porto
                  Maybe only some mosfet or voltage regulator has blown.
                  Is the fuse still good?
                  That monitor uses an external power supply, did you test it with your working monitor?
                  Do you have any advice at this point while budm is in surgery?
                  • mike in bremerton
                    • Jul 2017
                    I know it has been a little while but did you ever get the answer to fix the problem?
                    • mikey32230
                      • Jun 2013
                      • 19
                      A little while (6 years) later…
                      Unfortunately not. I probably still have the disassembled monitor laying around somewhere. I think I ended up desoldering something poorly, probably rendering whatever component useless, became too busy, forgot where I left off and gave up.
                      Sorry :/
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • Mita99
                        Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                        by Mita99
                        Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                        Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                        Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                        04-27-2025, 07:20 PM
                      • Dr.d
                        Help please..Lenovo ideapad 5 14itl05 power and charging problem
                        by Dr.d
                        I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                        Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                        04-05-2024, 11:48 AM
