LG W2252TQ-PF, high-pitch noise remaining after repair
  • TKMANKINDV2
    • Aug 2015
    • 9
    • France
    So... First, I am not an electronic enthusiast, I had few lessons in school several years ago but nothing really technical. No surprise if what I ask in this topic can be easy stuff for you
    My previous monitor (LG W2252TQ-PF, an 21" LCD monitor without LEDs @ 1600*1050 / 16/10) died one year and half ago. Before dying and for a good week, he produced an high-pitch noise at specific situations (in sleep mode, even offline but power connected, and between resolution changes) and so I expected it to stop working, and he did. Unable to start it again, I stocked it somewhere and replaced it by a new one.
    I wanted to repair it someday mostly by curiosity, and yesterday I finally got time and motivation to repair this old guy. I opened it, saw two bad capacitors but decided to replace nearly all of them (8, all Su'scon). Of course, I respected polarity/capacity, security and bought some decent replacements (Panasonic for the most part). The only ones I didn't replace was the two 68µf @ 450v but they didn't look bad.
    And he works again ! The image is fine in all areas, I don't see any problems BUT... he still produces the high-pitch noise he did before dying, in the same situations than before. Obviously, this sound is not coming from the capacitors or maybe from the 68µf ones I didn't replace ?
    I can't pinpoint the exact location of the sound, the only thing I am sure is that it come from the power board, but as I don't want to get an accidental hurtful discharge, I prefer to avoid getting too close of it while it is working, now that he got some power in nearly two years
    So I want to know your opinion of it, or if there is a way to know what can produce this damn sound offline.
    (I attached an image of the power board. It is not my image, I found it in the web but it is exactly the same board. If needed, I can produce some...)
    Cordialy,
    • 31214
    Re: LG W2252TQ-PF, high-pitch noise remaining after repair
    did you check the soldering for cracks on large items - specially the transformers?
    • TKMANKINDV2
      • Aug 2015
      • 9
      • France
      No, I didn't. I only took care of the capacitors.
      I will check and redo any suspicious soldering I will find when I have the time Until then, the monitor is unplugged.
      • SteveNielsen
        Retired Tech
        • 2327
        You can use a flexible plastic tube (like for a fish tank air pump) with one end to your ear (don't stick it in too far, just enough to hear through the tube) and the other to move around the area of the noise to help narrow it down to a specific part. Most likely a transformer or coil.
        • TKMANKINDV2
          • Aug 2015
          • 9
          • France
          SteveNielsen, I just tried your idea but I guess that I didn't have a good plastic tube... I think that 1/3 of the board, at the bottom-right of the previous image, has the highest volume with maybe a preference for the coil, but I can't confirm as the tool wasn't great.
          Just to be sure, I want to ask two informations from everyone :
          - In the first image I attach in this post, I guess that the curiously shaped soldering (not conique) must be replaced ? I can see this shape in multiple location, it will be a lot of work...
          - I think that the green (and solid) goo at D102 and D104 is some kind of glue in the second image, but can someone confirm ?
            • 31214
            the star shape on the soldering is fine - it's a rivet under the solder to make the board stronger.
            the green is threadlock used to stop the ferite beads vibrating
            • TKMANKINDV2
              • Aug 2015
              • 9
              • France
              Hello again,
              I tried redo some of the soldering, and I even replaced the two 450v 68uF as the sound seemed come from there, but the high-pitch noise is still here.
              That means that it is probably the transformer at location T101, the yellow-plastic cube at the middle-right of the first image. It is written AT0471 / LC SA01 L / TF-2820-W52.
              Unfortunately, I failed to find a location to buy a new one... Some people said that some glue can fix this problem, but I don't see where I should apply it (is this the datasheet ? it is visually similar and it is written TF-2820, but mine is partially enclosed). Build a brand new one is probably possible but not for me, I don't have the tools nor the time and competences.
              I guess that my best course of action is probably to buy an old powerboard on eBay from China, at least if I want to remain costly-efficient, or just don't care and unplug the cable when not needed. But for this last option, I want to know if this sound is just a sound or if it means serious problems at long term.
              • TKMANKINDV2
                • Aug 2015
                • 9
                • France
                Hello again,
                So... I let this thing "sleep" somewhere for a year and I just retried recently. Yes, I am somewhat stubborn
                I think I know what is generating this high-pitch noise : the blue cap at location C102 (cf screenshot). It is a 2200 pf 1kV capacitor. It is in the area where the sound come from and each time I touch it with a screwdriver (with caution), the sound change a bit. It is the only one who do that.
                As it is a high voltage stuff, I don't have any way to take some measurements, and I am not motivated to do that anyway, too dangerous.
                I tried to replace it by a new one after waiting some days that the board discharge itself... but the new one generate the sound too.
                So I am stuck. I wonder if I just have to sink it into some silicon, or maybe an other way ?
                • CapLeaker
                  Leaking Member
                  • 8330
                  replace it with a better one? are you sure that the noise is coming from that HV cap?
                    • 31214
                    i have heard of ceramics making noise - they can act like a piezo transducer.
                    what is more interesting, is why changing it didnt fix it and it never happened originally.
                    i wonder what it does, and if something has shifted its operating frequency?
                    • TKMANKINDV2
                      • Aug 2015
                      • 9
                      • France
                      Sorry for the VERY LATE response, computer crashed, bookmarks lost, etc. and life Now I am determined to finish it because if I failed, it goes into the recycle bin in a month at maximum. I need a second monitor asap as the one I had is dead.
                      So, hum...
                      I can't be sure at 100%, but I tried to touch the resistances and capacitors near C102 with the screwdriver (with the same ulmost care) but only the HV C102 cap does a reaction : the sound changes a bit, as long as I am touching it. I haven't try to test the transformer, as I don't know if I would get an electrical welcome. Better safe than sorry.
                      I can certainly replace it with a better one, I will buy some on the web. Just to be sure, I need to find higher voltage, but stay with same capacitance, right ?
                      It happened originally with the old cap, it was the reason I soldered a new one. I didn't expect that it would act the same, this is baffling me too.
                      • TKMANKINDV2
                        • Aug 2015
                        • 9
                        • France
                        Hello again,
                        I just changed the C102 blue cap with an another one, same capacitance but 3 KV.
                        There is no high-pitch noise while off anymore, this is a progress.
                        But, there is one similar noise while on, a very feint one. Apparently this sound disappear when the resolution is changing, and return once it has something to display.
                        It is not a trouble as it is not like the previous sound who was very loud, and even with new caps the rest of the monitor is still old so I guess it is normal.
                        Still, I only tested for 2 hours so far. No problem for the moment but I will try it with serious stuff to display once my real computer is back online (PSU gone, 7 years warranty, dead after 8 years ).
                        • tony359
                          by tony359
                          11-28-2023, 05:18 AM
                        • MegaZAC
                          Onkyo TX-SR805 noise in one channel
                          by MegaZAC
                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                          There's some logic behind it. As soon as I select an input I get only left...
                          04-23-2025, 10:09 PM
                        • courtcircuit
                          Philips HTS8000 home cinema noise problem
                          by courtcircuit
                          Hello
                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                          Removed each of tyhe boards
                          02-08-2025, 08:22 AM
                        • Biruslapio
                          LG 50PB690 power supply terrible noise
                          by Biruslapio
                          I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
                          As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
                          I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
                          07-13-2022, 12:46 PM
                        • tracid1987
                          Samsung LE40F86BDX (model 2007) noise in picture
                          by tracid1987
                          Hi
                          I have this TV bought back in 2007 and used it for playing on PS3 for 4-5 years actively. After then it was barely used. It was mostly in stand-by mode or plugged out of mains completely for years. Today when i turned it on i have noticed noise in picture on two different locations of the screen. As you can see on the photos (see attachments) the noise is only in a small rectangle area, and if you look at it closely you see that one noise rectangle area is at the upper left corner of first half of screen, the other noise rectangle area is at the upper left corner of the second...
                          08-21-2021, 01:48 PM
