lg 2234s no power at all
+ More Options
Posts
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Re: lg 2234s no power at all
    I tested the mosfet and is ok. I try a new one for sure but the problem remains.
    I dont have any voltage on the transformer in secondary in any pin consequently i dont have voltage to the output connector.
    In the primary of the transformer i have these DCV pin1 326V pin2(not connected) pin3 326V pin4 0V pin 5 0V.
    The dc voltage between two legs of c807 is 3,1V
      "The dc voltage between two legs of c807 is 3,1V" That Voltage is way to low for the SMPS IC to run. You already test the rectifier diodes in the secondary side to make sure they are not bad.
      The SMPS may be in the shutdown mode, or bad startup/running cap, bad SMPS IC.
      • vagos_89
        • Apr 2014
        • 61
        • Greece
        Yes i test the rectifiers in secondary and are good. Also i replace and c807 but nothing.
        Sorry but what do you mean "SMPS IC"? You mean the IC802 LD7522 on the bottom of the board?
          SMPS: SWITCHED MODE POWER SUPPLY.
          "You mean the IC802 LD7522 on the bottom of the board?" Yes, please see the spec sheet attached so you can see the pin out and how it functions.
          • vagos_89
            • Apr 2014
            • 61
            • Greece
            Thanks, i've already found the datasheet. I have voltage only in pins 1 and 7(3.1V). in other pins except gnd i have few mvolts.
            i put some solder on each pin but nothing.
            • Porto
              • May 2015
              • 109
              • NL
              #26
              According to the datasheet the Vcc has to be 15v nominal, and 30v max.
              Check all components between that pin and the rectified voltage on pin 1 of the rectifier, as Budm says, especially the caps. Not only measure the capacity but also the ESR if you are able to.
                There has to be DCV on pin 1 otherwise the SMPS will be in shut down due to BNO (brown out detection). You can have bad SMPS IC. You should also check the resistance between the VCC pin and Ground pin to see if it is really low and not allow the VCC to rise up to 16V (typ.) to run.
                see the spec sheet again.
                BNO
                Brownout Protection Pin. Connected a resistor divider from this pin to bulk
                capacitor voltage to set the brownout level and line compensation. When the
                voltage of this pin is lower than threshold voltage, the PWM output will be off.
                Brownout Turn-Off Trip Level min 1.05, typ. 1.10, Max 1.15 V.
                Like I said, check or replace the startup cap and the rectifier in the secondary side or just buy a new board and save time troubleshooting.
                You also do not have the main board connected while testing the output Voltage as I requested?
                • vagos_89
                  • Apr 2014
                  • 61
                  • Greece
                  #28
                  I tested the resistors and are all ok. I replaced the caps on primary(not smd) except the 150ΞΌF/450V because i didn't find the same, the rectifiers on the secondary and also the electrolytics there and i have the same measurements. i tested the optocoupler too.
                  If i have bad SMPS IC, the voltage on vcc not supposed to be right but to be bad the output voltage? If i understood correctly this voltage comes from optocoupler?
                  No i didnt had the mainboard connected when i measure. Nothing.
                  Already this board i bought fron ebay and comes to me faulty.
                    If you look at the spec sheet of the SMPS IC, you will see that the VCC for running the CI is generated by the AUX winding of the transformer once the circuit is running, when power is first applied to the board pin 7 (VCC) gets the start up through the resistor.
                    Again: Please see the spec sheet of the IC as I suggested.
                    As I also indicated, the pin 1 BNO cannot be at 0V.
                    At this point you will be off getting good working board.
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                      05-29-2024, 02:01 PM
                    • Mgiffune
                      by Mgiffune
                      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                      I ordered a supposedly β€˜new' Tcon board this time, and
                      06-09-2024, 10:28 AM
                      09-06-2024, 05:59 AM
                      HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 02:15 PM
