Dell 2005FPW Flickering - Seeking Tech Advice
  • w201
    • May 2015
    • 19
    Greetings All,
    My Dell 2005FPW display is getting to the point where it's unusable. Back panel is off. I can solder, but not good at troubleshooting. Hoping to get some tech help.
    The display itself does this thing where it will flickers on and off, sometimes it manages to stay on, other times it gives up and dies. Sometimes it will flicker on and off for 10 or 20 minutes and I manually pull the power cord out of sheer annoyance.
    A little bit of searching and my uneducated guess says that it's the capacitors. This monitor has a great picture but from what I've read it uses cheap caps. I guess that's about it. Any questions ask away.
    Thanks!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Dell 2005FPW Flickering - Seeking Tech Advice
    Caps are on the other side of the green board. Flickering sounds like it could be the ccfl tubes or the wiring to them though.
    • w201
      • May 2015
      • 19
      The ccfl tubes are on the actual display not the circuit boards correct? Are those fixable at all?
      • w201
        • May 2015
        • 19
        Found out ccfl tubes are replaceable but is there way to test to verify they're bad before I disassemble? On a side note- I did mention the display flickering...but I don't know if that's how to accurately describe the problem.
        I would say that a more accurate description is it repeatedly turns on and off- like it wants to turn on but can't- I never actually see a picture on the display, but I know that it's trying to turn on because the LED's also go on/off. Sorry if that's confusing.
          • 30952
          https://www.badcaps.net/forum/showth...er+testing+cfl
          • w201
            • May 2015
            • 19
            Thanks, will look into that.
            • w201
              • May 2015
              • 19
              Okay, I was going to try this out but I don't have spare connectors, but thanks for sharing anyway.
                You can just solder the wires to the connector pins on the bottom side of the board., this panel uses six lamps so it is going to be easy job.
                • w201
                  • May 2015
                  • 19
                  Okay, just so I'm clear, there's four different connectors on the backside (two are long and two are short), should I solder the cfl to each connector until I find the one that's bad?
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4938
                    • New Zealand
                    I assume there are 6 lamps, 1 on each transformer, but it looks like the long plugs have 2 pairs of pins, one pair looks like it's two outputs for 2 lamps, and the other pair the return wires for them, while the short plugs have 2 pins, a supply and return wire for 1 lamp each.
                    Show a photo of the underside of the board by those connectors so we can see what they connect to.
                    -David VanHorn
                    • w201
                      • May 2015
                      • 19
                      Hi Agent24,
                      I'm way over my head here, so thank you for helping out! Here's the picture you requested.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        Yes it looks like the wider connectors are doubling up to replace two of the smaller connectors each. That makes it a bit trickier but you can temp solder leads to the solder pads on the underside for testing if it comes to that.
                        • w201
                          • May 2015
                          • 19
                          Got it. Okay here's two more questions; I hacked open one 14W CFL. Do I need to hack open three more for a total of four bulbs so they're all connected at the same time? And would you be able to tell me which leads I should solder based on the nubmers that are on the board?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4938
                            • New Zealand
                            I would try first to run with all CFL lamps and see if there is a problem. If there is no problem, try swapping out one CFL for one panel lamp one at a time, and see if the problem comes back.
                            You could also swap one panel lamp for one CFL but that will show false results if more than one panel lamp is bad at the same time.
                            Run with as many CFLs as you can to start with, more chance of catching bad panel lamps if there are any.
                            -David VanHorn
                            • w201
                              • May 2015
                              • 19
                              Hi Agent24- sounds good. I'll have to try this after I hack open more cfls. Still unclear though about which leads I should solder to the long adapters as they have four prongs each. Unless I'm mstaken and you're saying the long adapters take 2 CFLs. I guess that would make sense if the display uses 6 lamps.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4938
                                • New Zealand
                                From what I can see, the lamp wiring is as I have marked on the photo. Red for lamp output from transformer, and blue for lamp return wire.
                                You can also look at the lamp plugs when plugged into the inverter - thick wires are outputs from inverter, thin wires are returns.
                                -David VanHorn
                                  • 30952
                                  incase you had not noticed, the board is printed to also handle 6 seperate connectors - one for each tube.
                                  so just solder onto the pads for each un-fitted connector.
                                  • w201
                                    • May 2015
                                    • 19
                                    Perfect! Thank you both. And I appreciate the diagram, Agent24. That will help out a great deal! Will post results when I get around to trying this out!
                                    • Ven
                                      Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                                      by Ven
                                      I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                                      The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                                      I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                                      If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                                      07-08-2024, 09:32 AM
                                      HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      09-06-2024, 11:39 AM
                                      HP ProBook 450 G6 + Spectre Tech Tote Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 450 G6 + Spectre Tech Tote Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Spectre Tech Tote boardview and 450 G6 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                      09-06-2024, 10:51 AM
