Another Dell 2005 FPW
    replied
    Re: Another Dell 2005 FPW
    I would say you do have bad connection at the end of the lamp.
  • Nightwolf
    replied
    I don't smell anything and it flickers about 1 to 2 min then screen is great! It sounds like it's coming from the lower left hand corner of the screen.
    replied
    Originally posted by Nightwolf
    Well I started trying to adjust brightness and contras and it has stopped making the arcing sound in the lower left hand corner and the screen is solid! Put it all back together and turned it back on and it was flicking just a little but went away in just a couple min. I'm thinking bad solder joint maybe?
    Do you smell OZONE! it sounds like bad solder joint at the end of the lamp.
    AM radio is good for listening for arcs.
  • Nightwolf
    replied
    Have to take it apart again to do it.
  • TechGeek
    replied
    It's still a good idea to pinpoint the joint and reflow. Could you trace it?
  • Nightwolf
    replied
    Originally posted by TechGeek
    Maybe get the arcing noise back again and then check where it's coming from, and then reflow the solder joint.
    It does it when it comes out of screen saver when its been off for more than 1 hour but stops after a few min.
  • TechGeek
    replied
  • Nightwolf
    replied
    Now on to the 1905 and 1907 monitors!
    Thank you all for your help!
  • Nightwolf
    replied
  • Nightwolf
    replied
    I'd swap the PSU's from both of these monitors.
    The one is bad, see first post. Inverter is bad on the other one.
  • TechGeek
    replied
  • Nightwolf
    replied
    OK I used the invertor board from this monitor and the main board from the other monitor and this is what I get now.
    View My Video
    Any thoughts?
  • Nightwolf
    replied
    Yes tried on 2 different systems
  • selldoor
    replied
    I would do it the other way round= as this screen is sort of working then the boards must be sort of working- so try the screen off the other monitor on these boards.
    Did you have a known working source connected to the monitor
  • Nightwolf
    replied
    The other monitor can be found here.
    https://www.badcaps.net/forum/showthread.php?t=44876
  • jasonbay13
    replied
    that sounds like it could be the ribbon cable or logic board.
    you said you had two of the same monitor, but the other one does not turn on?
    you could, if they use the same internals swap the power board with the one that doesn't turn on, and might have yourself one of them working.
  • Nightwolf
    started a topic Another Dell 2005 FPW
    I have another Dell 2005 FPW monitor with this problem. It has vertical lines thru out the screen. It not that the pic is blurry, but I took a small movie of the screen then took a screen shot of it. At least the screen comes on on this one. Maybe between the 2 I can make at least one of them work. Have not taken this one apart yet. Wanted to get some ideas first.
  • HTR-Informatique
    by HTR-Informatique
    02-09-2025, 06:51 AM
  • Swedishpower
    Dell G3 15 3500 black screen
    by Swedishpower
    Hello
    I have search everywhere for a solution for my problem, but cant find it anywhere.
    When I was away to trow some garbage i always look in the electronic bin.
    and this time i find a laptop.
    Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
    the lamp for charmig is white.
    Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
    but no Dell logo.
    I tryed with a hdmi cable to another screen, still black.
    I started to search solution and tryed...
    07-06-2025, 06:18 AM
  • jake-b
    dell e6540 boots to black screen (no dell logo)
    by jake-b
    good morning all,
    i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
    01-08-2024, 10:29 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • hcinne
    Dell G15 ryzen edition black screen 2 amber 1 white
    by hcinne
    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
    07-23-2024, 07:56 AM
