Fujitsu Siemens l22w - every time it is a new problem
  • benobeno
    • Jun 2010
    • 25
    • Slovenia
    Hello
    I had acquired a Fujitsu Siemens 22" LCD monitor in a non working state. I had replaced the capacitors and got nothing. Then I went and replaced the inverter transformer and the LCD was back to life.
    But yesterday after just a few working hours it died again. It just made a sould SSSSSS sound, went black and started smelling of a very bad electronic problem. And the button's led light was flickering very fast.
    I have disasembled it and I think I found the part that died, it is on the picture below, cause it smelled very bad. I think it is an AC-DC tranformer? So when the power cable is connected on one side there is 230V on every pin on one side and on the other there is 0V on each pin.
    So I am on the hunt for this part but I can not find it on ebay or any other site. So can anyone please tell me what part must i search for?
    Bye
    Re: Fujitsu Siemens l22w - every time it is a new problem
    "So when the power cable is connected on one side there is 230V on every pin on one side and on the other there is 0V on each pin." What did you use for the Ground ref. point for your meter?
    It is high frequency power transformer which is driven by the Power MOSFET SMPS IC, It is not driven by the main power line directly.
    Did you check the SMPS IC?
    • benobeno
      • Jun 2010
      • 25
      • Slovenia
      Hello
      Can you tell me which is this smps ic?
      Bye
      • selldoor
        Slow Learner
        • 7870
        Please can you update your profile with country and mains voltage
        • benobeno
          • Jun 2010
          • 25
          • Slovenia
          Done.
          • selldoor
            Slow Learner
            • 7870
            Ok - Thanks but we still need to know where did you place the negative lead on your meter
            when you said " one side there is 230V on every pin on one side and on the other there is 0V on each pin."
            • benobeno
              • Jun 2010
              • 25
              • Slovenia
              On the ground where the bolt is. Next to the AC cable connector.
              • selldoor
                Slow Learner
                • 7870
                "It sounds like you are not using the correct ground ref for the primary (hot) side of the circuit for taking the voltage readings on the primary side. The negative leg of the large 450vdc cap is the ground ref point for the primary circuits, do not use chassis as the ground ref point. The chassis is the ground point for the secondary (cold) side of the circuits." Quote from budm which is why he asked.
                Also can you do clear pictures of the backs of the board- the trasnfromer doesnt "look" burnt but there is some brown at the side of it.
                And see here :https://www.badcaps.net/forum/showpo...75&postcount=8
                If you have one of those it may be burnt as well.
                Another common fail for these seems to be the inverter transformer but that would not account for the lack of voltages
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
                • Thermaltake
                  Fujitsu Siemens Amilo Xa 3530
                  by Thermaltake
                  Hi, I got this Fujitsu Siemens Amilo Xa 3530 Model: MS2244. from a friend and it is powering On, but only functional keys lights up, fan spins and nothing else, screen is black no backlight, and it's staying like that forever. I tried other memory that I know is working, I tried to empty capacitors by holding power button without battery but still nothing. I didn't try new cmos battery, need to disassemble it first to try that. But I don't think even if cmos battery is dead it would give some backlight and picture...I kind of think it's chipset or gpu dead.
                  I read something on google that...
                  02-01-2024, 12:34 PM
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
                  Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook U Specification for Upgrade or Repair
                  This specification for the Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7511 boardview and LIFEBOOK U7511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-07-2024, 03:40 AM
