Samsung S23A550H Not Displaying Input
    Hey guys, I have a Samsung S23A550H and I'm having some troubles with it.
    It is an LED display so there is only one small board in it with an HDMI connector and a vga connector.
    When I plug the display into power but do not connect any input to it the screen switches between searching for HDMI and analog inputs no problem. The power button works but none of the menu buttons do anything. When I plug in a HDMI source the monitor detects is but when it switches over the the HDMI channel the screen goes black and the backlights turn off. The power LED stays on and the thing just sits there. If i unplug the HDMI cable then the monitor just goes back to the check signal cable screen. The same thing happens with the vga connector, with the exception of the power LED. When I plug in a vga source the screen turns off and the power LED starts flashing and stays like that. The PC that I plug the vga cable into detects the monitor no problem.
    I have read online that this may be a firmware issue? If so how would I upgrade the firmware? I know the display is working becuase it will sit on the check signal cable screen indefinetly. I checked the fuse and a few diodes on the board and they all checked out fine. There were also some voltage testpoints on the bottom of the board which also tested fine.
    I hope that this is an issue that can be sorted out without a bunch of work.
    Any suggestions are appreciated.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
    Re: Samsung S23A550H Not Displaying Input
    Anybody?
    canadaboy25
      http://www.samsung.com/hk_en/support.../LS23A550HS/XK
      https://cdn.badcaps-static.com/pdfs/...4b5e8fc605.pdf
        I doubt that this error is caused by corrupted firmware. Check my earlier post in https://www.badcaps.net/forum/showthread.php?t=29987
        You'll find a number of links to other threads dealing wih this error on Samsung SA LED monitors. There's a description of the symptoms the monitor shows when the firmware is corrupt as well as a guide how to upgrade the firmware.
        re-atari
          I was having similar problems to the folks in this thread with a samsung syncmaster SM23550AH. No or intermittent video, most recently when trying to get it working with a lenovo m720q displayport to hdmi dongle and then the same lenovo and a HP port replicator HDMI to the monitor. ultimately, I was able to get video on the svga connector with an old laptop. I ended up using windows 7 and svga to install the driver and firmware upgrade. heads up that the driver asked me if I wanted the analog or digital driver. I installed the digital- i think you can only do one or the other because rerunning the driver will ask you if you want to change or uninstall IIRC. anyway, this ended up resolving the no video issues I had.
