Need help with what to do.. guide me please
  • Agent24
    I see dead caps
    • Oct 2007
    • 5111
    • New Zealand
    #61
    Re: Need help with what to do.. guide me please
    Heh, it's the way I've always done it myself. I know there are better ways but I go with what is easier in the situation, which is usually this. As long as the component can't move I think it's OK. That said I am going to have to replace an IC socket on a double-sided board where half the pads came off due to a battery leaking. That will be a bit more fun. Luckily it's only two layers.
    -David VanHorn
    • reaper57
      • Sep 2014
      • 216
      • Norway
      #62
      Have you ever (and how if you have) repaired multilayer boards?
      I usually like to make solder "bridges". Which is basically just getting the solder to stick to my iron and just moving it from the pin to the trace. The pads I usually have to repair are for ICs or sockets where the pin and the pad/trace are very close so a solder air bridge is the easiest thing for me to do, and the most fun if you're into solder modeling.
      Keyboard not detected, press F1 to continue...
        by momaka
        03-15-2023, 10:17 PM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
