Samsung SA850 screen flashing/lines/not switching on
  • rash.m2k
    • Apr 2010
    • 64
    Hi All,
    I've got this monitor and of course it is not working.
    it has a seperate power supply, so it can't be that.
    The screen flashes on, stays on for a few seconds then goes off. The power led is constant though. It could be that the actual power supply is 4A and I only have a 3A one (going to buy a 4A soon).
    But that doesn't explain the lines down the screen.
    Hoping someone can help me fix this or happy to send it to someone to fix it for me! (in the UK)
    Given these as links as the images are very high res:
    https://farm6.staticflickr.com/5575/...5f005db8_o.jpg
    https://farm6.staticflickr.com/5570/...0880e94d_o.jpg
    https://farm4.staticflickr.com/3917/...259706b0_o.jpg
    https://farm4.staticflickr.com/3852/...845870f5_o.jpg
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung SA850 screen flashing/lines/not switching on
    Just a few problems with your post
    1 Please can you update your profile with country and mains voltage.
    2 Pictures tell little - what lines down the screen?
    Reduce the size of your pictures to less than 3mb jpg and you can post them using manage attachments. You need to post one of the Led driver board if there is one and also report the voltages on the socket with the black and 1 blue wire with respect to ground. Find and test any voltage regulators.
    See 2 seconds to black guide sticky at top of this forum ( mainly for ccfl backlights but has lots of useful tests start at post19)
    • rash.m2k
      • Apr 2010
      • 64
      Dude! Where abouts in Lancashire are you? I'd be happy to drop it off to you can pay for your services!
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Heheheh - I have enough problem machines of my own !!- need to see the picture of the lines down the screen - I suspect it is going to be a bad panel so probably a waste of time trying to fix the rest.
        • rash.m2k
          • Apr 2010
          • 64
          heres a pic of the lines mate and the voltages too.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            " Car repair man intake of breath" Fsfsssssssssshs.
            Doesnt look good - does it always appear in the same place?
            There will be a cable goes to the panel from the main - LVDS
            If that is removable try removing cleaning and replacing.
            • rash.m2k
              • Apr 2010
              • 64
              Fortunately no its not in the same place, cleaned contacts no luck, I've got a video i'm uploading now. It flashes a few times first then comes on and I can see the lines moving across the screen.
              ok here is the video:
              https://app.box.com/s/z4ilsnvm3u6sqk5if49t
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Hmm - does it have a tcon or is it all on the one board does that metal cover come off
                easily?
                • rash.m2k
                  • Apr 2010
                  • 64
                  easily?
                  tcon board - yes (if I understand you correctly) it does have one and the connectors are soldered on to the display.
                  The metal cover does come off, but would need to be de-soldered.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    perhaps a picture of the tcon? panel board might yield some clues.
                    • rash.m2k
                      • Apr 2010
                      • 64
                      See attached, I also have images that are taken closer so you can make out more detail (>2 of course)
                      • rash.m2k
                        • Apr 2010
                        • 64
                        Ok, I've done some more tests. Tried a DVI connection and the monitor is detected and the screen changes from black to all blue which white/grey/possibly other colours lines - and I can see a vertical think white/grey bar which moves across the screen when I move the mouse (so must obviously be the mouse pointer).
                        The USB ports also work (plugged in my phone to charge).
                        I suspect you may be correct in that the Tcon board could be faulty - if a component on the tcon board can be replaced easily thats fine, otherwise I may be screwed
                        OK I've switched it on and two chips get very hot, I accdently touched it, one of them reads as E7=DL AOB (unsure if zero or O between) and the other reads 17814HS P247NFH (3 of these in total and the others don't get hot)
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          Ok - well at least the fuse is working
                          There is a voltage regulator on there, near the fuse - U??? perhaps test that if its supply ing an off voltage perhaps other items are overworking (heating) to compensate.
                          I thought I found something about the 17814HS but got distracted and lost it.
                          Perhaps a picture of it and the other you mention?
                          That mini hotair blower seems to be a medical gadget - I posted a link in the other thread.
                          • rash.m2k
                            • Apr 2010
                            • 64
                            Yeah - I thought I saw something about the 17814HS on the polish forums, but nothing concrete.
                            Where is the voltage regulator? Is it the black component below the ribbon connector on the left? And looks like like this but a bit has no screw hole? http://m2.uxcell.com/photo_new/20110...x0169_ux_c.jpg.
                            Ok so reading from left to right (and upside down as in the picture above), the voltages are
                            4.58 ==== 3.287 ==== -1.7
                            And the big tab is 3.287v
                            Be easier if I just brought it to you?
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              Yes I think you have the right one - IC3 - what is the part number on it?
                              I have never heard of one having a negative voltage? or is it just 1.7
                              Ok see picture now it is one of these
                              http://www.richtek.com/download.jsp?...RTOTE2NEMtMDND
                              So output is correct. 3.3v
                              • rash.m2k
                                • Apr 2010
                                • 64
                                Nope, it's definitely negative 1.7, if I connect the multimeter legs the other way round it becomes positive and the others become negative.
                                Also there are marks on the plastic film on underside metal cover of the tcon board (I can remove them by rubbing it), they are directly above the chips that I said get hot (just to the left of the ribbon cable)
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  Ok - looks like we are stuck less we can find datasheet - nothing at all for the other one
                                  • rash.m2k
                                    • Apr 2010
                                    • 64
                                    Yeah, aren't even able to buy the component!
                                    But I've checked the voltage on the corner pin and it's almost zero (0.19mv) on the one that gets really hot, same pin on the other two ICs register at 4.6/7v.
                                    Similar thing for the other corner pin, 1.something volts vs 4.6v.
                                    • jeyoung12
                                      Samsung QN50Q60t lines on screen
                                      by jeyoung12
                                      Hi all
                                      I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                      My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                      This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                      It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                      So....i don't know what end of the C ribbon to work with...
                                      02-26-2024, 10:38 AM
                                    • HTR-Informatique
                                      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                      by HTR-Informatique
                                      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                      I also changed the screen because the PC fell and the screen was broken.
                                      I changed the battery with a new and original battery.
                                      I also had corrosion/oxidation on the...
                                      02-09-2025, 06:51 AM
                                    • Stanley1843
                                      Screen Display Vertical Multicolor Lines
                                      by Stanley1843
                                      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                      06-29-2024, 11:54 AM
                                    • Chrissygizmo
                                      by Chrissygizmo
                                      02-10-2025, 12:33 AM
                                    • Runlinc
                                      Samsung QE50Q60TAU - Horizontal screen lines
                                      by Runlinc
                                      Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
                                      I am left with a good image apart from the black horizontal lines that I cannot get rid of.
                                      I cannot find anything on the buffer boards that has shorted.
                                      Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
                                      Many thanks for your assistance
                                      05-14-2024, 07:40 AM
