ACER AL1916W Orange Light Only
  • imadunatic
    • Jul 2014
    • 21
    Hello, after all the help I recently had on a Samsung TV, I was hoping you guys could help me out one more time. This time the patient is an ACER AL1916W monitor that has been working fine up until yesterday afternoon. The orange light stays on, power button does nothing (won't turn the monitor off or on, LED never changes from orange). I unplugged for 24 hours (because that always works I guess???) and hoped that would somehow magically fix it, alas, it was not to be.
    I opened the case hoping to find bulged CAPS (and maybe an easy fix?); however, that wasn't to be the case. I have no idea where to begin testing on something like this so I would like to thank you in advance for any guidance. I'm hoping to save this old girl...
    I've attached large pictures of the boards. Thanks again.
    Kevin
    Re: ACER AL1916W Orange Light Only
    So when it is does not detect the video from running PC, it stays in standby. It can be the logic/scaler board problem. There are two 3-pin SMD voltage regulators on the top left of the logic board, you can try heating up that section with hair dryer to see if it will response, otherwise take the DC voltages of all 3 pins and report the readings, use chassis as the ground ref point (board has to be mounted so the ground pads on the board will make contact with the chassis).
    • imadunatic
      • Jul 2014
      • 21
      Hello again Bud. I've attached a pic of what I'm seeing. All values are DCV.
      Edit: No response after heating either. Computer detects monitor... monitor doesn't detect computer...
      Last edited by imadunatic; 08-18-2014, 06:30 PM. Reason: Forgot to include results of heating.
      • selldoor
        Slow Learner
        • 7870
        Those seem ok - does the part number indicate 33 an 18 respectively
        see here https://www.badcaps.net/forum/showth...999#post300999
        Have you tested the small yellow fuse - top right. NO power to board
        Meter on ohms 200 should read the same as touching the probes together
          Same result using DVI?
          • imadunatic
            • Jul 2014
            • 21
            Selldoor, I will have to double check the part # when I get home, I can't make it out in the pictures. Also, please excuse my ignorance, but I can't tell which is the fuse? Is it visible in the picture I posted the voltage checks in?
            Bud, I did check the VGA and DVI with no luck; this happens to be in a dual monitor setup so I had the luxury of testing cables and ports between the two to rule out my video card and cables.
            Thanks again,
            Kevin
            • selldoor
              Slow Learner
              • 7870
              Fuse is in your picture pic 1 top right corner - it will say F*** on the board next to it.
              • imadunatic
                • Jul 2014
                • 21
                Ok. I found two fuses on the power supply board, they both check little to no resistance (but not infinite). Continuity checks ok. Are there any fuses on the logic board I should check? I only found two components that started with an "f", but they are both "FB###". Not sure what these are?
                Selldoor, the voltage regulators do state 33 (top in my pic) and 18 (bottom in my pic).
                • mosfetratus
                  macbook A2918, orange light off when shut off
                  by mosfetratus
                  When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                  Works with battery and charges, but when i shut off i get this problem.
                  It had liquid spill. Board has no corrosion, keyboard is working, power button...
                  05-31-2024, 03:34 AM
                  09-06-2024, 05:27 AM
                • jheunne
                  A1466 macbook no boot green to orange light help
                  by jheunne
                  i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                  in first image there is 0v out for lcd
                  https://ibb.co/5XppmpkH
                  in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                  https://ibb.co/fdJkbJs8
                  06-10-2025, 10:52 PM
                • Rezendes
                  820-3115-B No Orange Light, Won’t charge battery
                  by Rezendes
                  Hello, I have a MacBook 820-3115-B board that never shows an Orange light and goes straight to a green light and turns itself on when the ac adapter is plugged in. System won’t run off battery and turns off immediately when ac power unplugged. I believe the battery should be ok as it was a replacement not too long ago but it’s possible that’s the issue as most anything is possible I guess. I don’t have any spare batteries or donor boards although I have ordered 2 on the way. I have replaced U7000 and same results. I have also applied flux and reflowed the SMC IC and no change. Nothing...
                  06-23-2024, 12:56 PM
                  Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                  This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-07-2024, 05:00 AM
