YP1922-4L LCD power board repair
  • Honziq
    • May 2014
    • 58
    • Kazaksa
    I have LG LCD TV. When I turn on the TV backlight turns on for 1 sec and then goes back off. I think it is bad invertor. But i dont know, which of components is bat. MOSFETs and caps seems OK.
    Help me, please.
    Thanks.
  • selldoor
    Slow Learner
    • 7870
    Re: YP1922-4L LCD power board repair
    Ok you need to test the inverter transformers secondary windings.
    No Power to Board
    Meter on Ohms 2000 test S1 to S2 and S3 to S4 and post the results
    I will be going to bed soon - early start tomorrow - someone else might follow up
    Which country are you in and mains voltage
    • Honziq
      • May 2014
      • 58
      • Kazaksa
      No Power to Board
      S1 to S2 - 1080 Ohm
      S2 to S3 - 1092 Ohm
      • Honziq
        • May 2014
        • 58
        • Kazaksa
        No Power to Board
        I am in Czech Republic, mains voltage is 220V.
        • selldoor
          Slow Learner
          • 7870
          Ok they look alright. Are the leads on the lamps long enough for you swap each pair over.
          Often the bulbas at the top age faster and developa a higher resistance.
          Do you have any spare bulbs /another faulty ,even broken monitor or laptop screen.
          • Honziq
            • May 2014
            • 58
            • Kazaksa
            Thanks,
            i try to swap tubes with one laptop screen tube.
            One of the top tubes is bad. When laptop screen is connected TV running always.
            Thanks a lot.
            • selldoor
              Slow Learner
              • 7870
              Good - Hopefully you can get a tube for it - if its just for yourself and is watchable with just 3 lamps I have heard of people just sitting a bulb inside the back to make it work but to save having to attack the panel. Bulb fitting can be quite tricky.
              • Lumberjack777
                • 464
                Nice job diagnosing that problem so quickly selldoor.
                I'm one of those people that simply tapes a bulb about the same size or smaller to the panel. And cover it with black electrical tape or duct tape. Unless its a valuable monitor, its way too much trouble to disassemble and spend $15 or more for a bulb for a $25 monitor. We might start replacing with LED strips someday soon.
