Replacement CCFL lamps
  • terry
    • Oct 2007
    • 91
    • Milton Keynes, Bucks
    I am after 24 x 19" wide screen CCFL tube to repair some 19" HP monitors. I have just found a website with them at a good price http://www.ledbos.com
    Has any one used them before, or are they to good to be true?
  • terry
    • Oct 2007
    • 91
    Re: Replacement CCFL lamps
    Here is a link to the one I am looking at
    http://www.ledbos.com/index.php?main...x&cPath=98_100
      • 31094
      i use:
      http://stores.ebay.com/lcd-led-parts
      the one you linked is about right for chinese costs, but you have to remember the shipping.
      also the u.s. couriers WILL hit you for import tax.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        http://www.ccfldirect.com/
        http://www.ccflwarehouse.com/
        • Rtech
          • Jul 2010
          • 1095
          Try...http://www.iccfl.com/ I use them fpr CCFLs
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            ccflwarehouse also have an ebay outlet - see here:
            http://www.ebay.com/itm/301211421547
              • 31094
              looking at all those links,
              i cant believe how much people are being ripped off by those company's
              a tube is worth a couple of $ max.
              add one or two for the post.
              those companys must be rolling in cash, the wholesale price of cfl's is under 50c
              • the_rem
                Unknown transformer : how to find a good replacement part ?
                by the_rem
                Hello guys,
                I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                04-23-2025, 01:48 AM
              • Jagster
                Panasonic SA-XR25,Looking for a good replacement cap
                by Jagster
                I have a Panasonic SA-XR25 surround receiver that is not working and I believe it may have a faulty capacitor. This large capacitor near the mains power input has a plastic top that is bulged out. Anyhow, I'm trying to find a like replacement but Panasonic doesn't seem to make this capacitor any longer and I want to find a suitable replacement. It has an "AUDIO" designation written which I presume means something important in relation to the capacitors design characteristics. Can someone advise on what would be a good replacement? Image attached.
                The sleeve info:
                10-27-2022, 09:34 PM
              • angelos
                Sinotec LCD TV Model ST-42KC42F "CCFL lamps not switching on"
                by angelos
                Hi Guys,
                It's been a while that i have been active on the forum, sorry for that. My primary job has been keeping me quite busy.
                The above set starts up with sound working just fine but the CCFL lamps (Inverter) runs for one second and switches off.
                My 24V supply is steady and the ON/OFF pin to the inverter is at +5V.
                The only thing i see is the PWM signal pin is at +5V without any square wave being emitted. Is this normal? as far as i can remember there needs to be a square wave pulse there. Am i right?
                I will now measure with my oscilloscope probe on...
                06-11-2023, 02:14 AM
              • Topcat
                Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
                by Topcat
                This was rescued from a recycle gaylord from a hospital along with some other things....
                I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
                Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
                08-02-2023, 10:07 PM
              • mikey5791
                Help on Samsung Syncmaster T220 dead ccfl lamp
                by mikey5791
                This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                10-18-2020, 03:17 AM
