dual vs single channel LVDS panel swap...possible?
  • sweetdaddyjones
    • Feb 2014
    • 7
    I understand that in order to get the timings right and deliver all those pixels, dual channel LVDS is used for resolutions above 1280x800 (or somewhere around there), but are both channels still used at 640x480, or is the second channel used only when at resolutions when the timings would be unsuitable for 1? Basically, I have working controller boards from displays whose (2CH LVDS) panels were smashed, and I have working (1CH) panels from old laptops, but no controller boards--i was wondering, if wired properly, can I connect these as long as I run them at low resolutions?
    My gut tells me that the innards of the monitor are probably always using both channels, but I'm hoping that sometimes the manufacturers would use the same controller boards with smaller panels in cheaper models...
    it's a shot in the dark, but hey...i'm trying. ;x
  • Hondaman
    Single-channel antenna?
    by Hondaman
    Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
    I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
    Years ago I made a "T"...
    11-18-2024, 01:14 AM
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • spleenharvester
    Reverse engineering of 18650 4-channel tester
    by spleenharvester
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
    05-04-2025, 02:43 AM
  • mikey5791
    Help on car amplifier only one channel works
    by mikey5791
    Hi all forum members,
    Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
    My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
    08-06-2025, 10:36 PM
  • dicky96
    Hitachi V19B01922 Channel Tune problem
    by dicky96
    Hi Guys
    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
    He also has an LG TV, so three screens in the bar
    I installed three Satlink ST-6503 DVB-T Modulators
    This model https://www.aliexpress.com/item/32916553905.html
    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
    02-09-2023, 09:20 AM
