Two computers on one monitor and view both of them at the same exact time
    • Jul 2011
    • 6068
    Back to the topic that was originally discussed
    I did buy the split screen device to try it out I will post the results of testing it once I get and hook it up
      • Jul 2011
      • 6068
      https://www.ebay.com/itm/16690324712...Bk9SR67IsonGZA
      I bought one of these split screen generator and it works perfectly for how I am wanting to use it when I get the computers setup with the battery testing machine I will take a picture of the monitor screen
      The one I bought does not come with the remote but I going to buy another one and this time I will make sure that it comes with the remote
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        For what do you need the remote for?
          • Jul 2011
          • 6068
          To switch between screens instead of going up to the device but I also want another one for the other computer cart that I have as well and that one I do not need the remote for
          • Adubey
            • Oct 2020
            • 21
            Sam, This is possible via the hardware route where you take identical monitors and pry open the LCDs and remove the backlight and filter from one of the monitors leaving only the LCD layer and then disassemble the other monitor and insert the bare LCD from first monitor into second. You will need quite a bit of skillset to be able to do that.
            However when I read your original usecase, you can go software route of using HTML and javascript to show the twobattery monitors without disturbing any of the screens and doing delicate maneuvering of hardware approach. This way the look and feel can also be customized and you can scale up to even multiple different chargers.
              • Jul 2011
              • 6068
              Originally posted by Adubey
              Sam,
              Exactly how do you do this by software route and how would you hook it up to be able to use it
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                #27
                You seem to have already solved this, but how about two HDMI/USB video capture cards ? Then open two capture windows on the target machine/display ?
                • Adubey
                  • Oct 2020
                  • 21
                  Sam, There are multiple ways to do this - depends on your interfaces and what role those computers play on the battery testers, and the software capabilities... there is a software called Nagios, using which you would write your own scripts and capture the data from each of these computers, and then collate them to represent it on a dashboard..
                  you may be able to take use of Copilot using which you can screen scrape the data from the computers and populate a table and then display them on screen...
                  these are not the only two ways as there are multiple ways of doing this.. to start with read these approaches and see if they can help you.. honestly if its just battery monitoring some bms support data via snmp..
                    by momaka
                    03-15-2023, 10:17 PM
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
                  • Rick_1234
                    by Rick_1234
                    Good evening, gentlemen.
                    Things I tried
                    06-22-2024, 04:44 PM
                    Wise Wing F199 19'' LCD monitor - recapped
                    by momaka
                    Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                    I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                    When I saw the Craigslist post, I wasn't...
                    08-24-2020, 10:58 AM
                  • sew333
                    Pc shutdown, monitor flickered with no signal after 10 seconds
                    by sew333
                    My pc:
                    10850K stock 4800mhz stock Kraken X73 good temps
                    2x16 GB DDR4 GSKILL 3000mhz XMP
                    Seasonic Tx-850 Ultra Titanium
                    Gigabyte Rtx 3090 Gaming OC
                    Aorus Z490 Pro Gaming
                    1 TB SSD
                    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                    Power...
                    02-22-2022, 10:27 AM
