Wiewsonic VE710b black screen Flashing
  • rogebe
    • Feb 2014
    • 37
    • france
    Re: Wiewsonic VE710b black screen Flashing
    Hello budm,
    You are right, the condenser C3 seems bad (the eye of master !)
    For the yellow cap, I put it a which was between two good transistors.
    Something else ?
    Nice day to you.
    RGB
      That bad filter cap C3 for the inverter power supply can cause the Royer Oscillator (the two C5707/5706, the tuning cap (0.22uf yellow cap), the inverter transformer) to run at the wrong frequency which will cause the transistors to run hot and burn up.
      If I were you I will replace the electrolytic caps as a set, not just C3. Bad cap can look normal.
      • rogebe
        • Feb 2014
        • 37
        • france
        Ok Budm,
        I made a photo
        In red the condensers which are before D108. It is a s à high voltage power rectifier. He has to feed both Royer Oscillator (inverters).
        Transistors on the right was OK. Those on the left not
        Normally caps in the red circle must be good
        Rest C3 and C108 has to change
        I am clear ?
        It is right ?
        Thank's for you answer.
        RGB
        • viziks
          • Mar 2012
          • 33
          • India
          Please also check 0.22uf condensers between the 2 C5707 transistors.Defective capacitor will cause transistors to overheat.
          I hope you must have also checked and resoldered both inverter transformers near the transistors "100179 ".
            Post 20 also requested to check the capacitance of those two 0.22uf cap, but I am not sue if he did or not.
            • rogebe
              • Feb 2014
              • 37
              • france
              #26
              Before switch on the board I think resoldered both inverter transformers.
              As I have two same boards (in fact, I have 4 same screens), I took transistors and yellow caps (0.22µf) which was good to replace on the other board.
              But I am going to unsolder the yellow caps and to verify their value
              However I do not see these transistors " 100179 " ?
              The reflextion on the post 23 is right ?
              C3 is very important for Royer Oscillator ?
              What is the fonction of C108 ?
              Thank you for you interest in my problem.
              RGB
              • rogebe
                • Feb 2014
                • 37
                • france
                #27
                I resoldered the two inverter transformers.
                I measured the two yellow caps: 0.211 (scale 2uF).
                I changed C3.
                Good day for you.
                RGB
                • rogebe
                  • Feb 2014
                  • 37
                  • france
                  #28
                  Hello guys,
                  I had no answer to my last questions.
                  Needs it to make the other thing ?
                  Thank's for you answers.
                  Good day.
                  RGB
                  • rogebe
                    • Feb 2014
                    • 37
                    • france
                    #29
                    Up
                    • rogebe
                      • Feb 2014
                      • 37
                      • france
                      #30
                      I have to go back up the board and the screen works again.
                      Thanks to all those who gave me somme ideas to repair.
                      Finally I have to change two transistors (Q10 and Q11), C3, to check condensers yellow and to resolder transformers.
                      Well I have two similar screens to be repaired.
                      Coming up next.
                      Good day.
                      RGB
                      • rogebe
                        • Feb 2014
                        • 37
                        • france
                        #31
                        Hello
                        I repaired an other one.
                        2 on 4 but I do not have transistors anymore to be cannibalized.
                        Still one thank you.
                        Nice day for you.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5038
                          • New Zealand
                          #32
                          Did you have a look on eBay?
                          -David VanHorn
                          • HTR-Informatique
                            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                            by HTR-Informatique
                            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                            I also changed the screen because the PC fell and the screen was broken.
                            I changed the battery with a new and original battery.
                            I also had corrosion/oxidation on the...
                            02-09-2025, 06:51 AM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
                          • dbuergi
                            Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                            by dbuergi
                            i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                            Any ideas where to look?...
                            11-07-2024, 10:57 AM
