Samsung U28E850R power supply ( p6514_fsm) driver IC
  • proditaki
    • Aug 2023
    • 18
    • Netherlands
    I have for mentioned Samsung Monitor which is showing no signs of life
    Upon inspection of the power board it looks like the mosfets gave up which took out the resistor, like expected, but unfortunately also the driver IC.
    The ic is, unfortunately, beyond recognition.
    I was wondering if someone can inform me which ic goes here.
    See attached images.
  • R_J
    • 9590
    In a case like this the first thing I would do is look in the unit to see if the ic top is somewhere, even a partial number might help. What are the numbers on the mosfets? maybe a similar schematic can be found.
    I suspect it is a S3310A even the 9 of the date code looks similar
    • proditaki
      • Aug 2023
      • 18
      • Netherlands
      Thanks for the reply.
      I've looked but can't find (part) of the cap anywhere. (found the top of the burned resistor, but that's it.)
      Someone suggested it might be a S3311 and you could swap that with a NCP1200D60R2G.
      But that was based of samsung regularly using the S3311 in other devices, not any experience with this particular power supply board.
      The mosfet is a 60s360p7.
      If i can't get the power supply to work at all i might convert it to use an external 14v power brick, which aren't too expensive.
      • R_J
        • 9590
        The bn44-00605a circuit is very similar in that area (component values different) What is left of the ic does seem to suggest a S3310 (you can see part of the last digit 0)
        I didn't look close enough at the picture for the mosfet number, now that I did I see what looks like a small burn mark above the C in QM801CS, I would check that CM801 is not bad, either shorted or it may just be cracked, they do like to short and should be replaced with a 2kv type, not the usual 1kv.
        It looks like something shorted to QM801CS drain pin on the top photo
        • proditaki
          • Aug 2023
          • 18
          • Netherlands
          Oh yeah the mosfets QM801CS is shorted completely. Thats the 60s360p7. I already removed that from the board
          The mosfet is probably the first thing that failed.
          • proditaki
            • Aug 2023
            • 18
            • Netherlands
            I'll check cm801 as well thanks.
            I ordered replacements for the broken parts.
            The cap i should have. Otherwise i can source it at the local electronics shop
            • R_J
              • 9590
              I would also replace CM806, the cap on the vcc line of the ic, they usually go bad as the power supply is always on.
              • proditaki
                • Aug 2023
                • 18
                • Netherlands
                Thanks, will do
                • proditaki
                  • Aug 2023
                  • 18
                  • Netherlands
                  Turns out it wasnt the right driver ic.
                  I'm not gonna spend much more time on this. I'm converting it to use external power.
                  Printed an adapter plate and added a jack.
                  Click image for larger versionName:	PXL_20240701_151230906.jpgViews:	0Size:	312.7 KBID:	3300306
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • cheeky2
                    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                    by cheeky2
                    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                    06-15-2025, 05:12 AM
                  • Cookybaby
                    Samsung UN60ES6500FXZA Power Supply Issue
                    by Cookybaby
                    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                    Make: Samsung
                    Model: UN60ES6500FXZA
                    Power Supply P/N: BN44-00525A
                    Symptoms: The TV was...
                    08-20-2023, 12:26 PM
