IBM Thinkvision 6736-HC9 No power
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4548
    • Italy - Milan
    #41
    Re: IBM Thinkvision 6736-HC9 No power
    OK mosfet is good, not bad since it's expensive :-) , i have doubts about those low readings on the smps ic.. why don't you test carefully pin 8 HV and pin 6 Vcc in volt? To be sure that the part is same as what i found check if pin6 is connected to pin+ of little near electrolytic.
    • eckertb83
      • Jan 2011
      • 71
      I'm not exactly sure what you are saying.
      "why don't you test carefully pin 8 HV and pin 6 Vcc in volt? To be sure that the part is same as what i found check if pin6 is connected to pin+ of little near electrolytic."
      Pin 8 HV DCV?
      Pin 6 VCC? I've never heard that before.
      Pin 6 connected to + of little Eletrolytic? you mean capacitor right?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4548
        • Italy - Milan
        #43
        test those 2 pins of smps ic in Vdc. HV, Vcc are the names of the pins..
        "Pin 6 connected to + of little Eletrolytic? you mean capacitor right?"
        yes, that little electrolytic (lost a "C"..) capacitor on the primary side.
          "all done with back probe on PIN 4 Ground.
          1-004
          2-046
          3-001
          5-002
          6-329
          PIN 7&8 just a 1 one the left no resistance."
          So are they in Ohms, K Ohms. If 5 is 2 Ohms, that will be bad for sure.
          And how about those two caps and DC voltage readings on the connector on post 36? There are pins with 5V label on them. We are testing the board by itself to make that if there is shorts on the main board that may cause the power supply to be in the shutdown mode, we know that you do not have shorted out MOSFETs which will cause the power supply to be in shutdown as well.
          • eckertb83
            • Jan 2011
            • 71
            I havent heated up the 2 little caps yet, but did test the voltage going to the logic board and the 3 pins labeled 5v I was getting about a 1v reading. I will heat the 2 small caps up and see if that changes anything
              OK, at least it is trying to put out something, you may as well replace those two caps,, they are part of the set of caps that should be replaced any way.
              • eckertb83
                • Jan 2011
                • 71
                Ok I will put them on my list of stuff to order. So with not getting a reading on the IC pins 7&8 I as assuming that is bad and needs to be replaced as well? Did you happen to see the pic I posted of it? is the 1203D6 the correct part #?
                  Pin 7 is not used or present, pin 8 is the HV pin should have high resistance. You might as well order the IC.
                  But I will wait for the result of heating the caps with hair dryer first. We still do not know what DC voltage you get at pin 8 (HV) and pin 6 (Vcc) using pin 4 as the ground pin for your DC meter.
                  Without having the test result of the voltage reading we cannot know what is going on, also still no Ohm, K Ohm on your resistance readings you have posted does not help us out either, that pin 5 reading of 002 in Ohms, K Ohms, M Ohm?
                  You might as well replacing a set of caps and the IC and hoping that will solve the problem.
                  • eckertb83
                    • Jan 2011
                    • 71
                    I'm sorry I still dont understand the difference between ohms, K Ohms and M ohms and the settings on the DMM. I will google it..... So I know for future reference. I had my DMM set 2000K so I would guess K Ohms.
                    • eckertb83
                      • Jan 2011
                      • 71
                      1-004------4000Ohms
                      2-046------46000Ohms
                      3-001------1000Ohms
                      5-002------2000Ohms
                      6-329------329000 Ohms
                      Does this look/sound right?
                        OK, they do not look bad, but how about pin 8?
                        • eckertb83
                          • Jan 2011
                          • 71
                          Ok Finally was able to get back to this,
                          Resistance on Pin 8 with ground on Pin 4 is 850000 Ohms Its probably more than this after holding it for about a min it just kept climbing.
                          Voltage for Pins 8 & 6
                          Pin 8 161DCV
                          Pin 6 5.9-8.3dcv it bounced around between these numbers
                          Also Heated up the 2 small caps and there's NO Voltage change on the 5v pins going to the logic board...
                            "Pin 6 5.9-8.3dcv it bounced around between these numbers" That VCC voltage for running the IC is too low, and with that fluctuation, it can mean the filter caps (2 small caps) are not doing its job. So at least you will have to replace those two caps.
                            • eckertb83
                              • Jan 2011
                              • 71
                              and the IC is ok or should I get one and replace it as well?
                                Get the IC as well.
                                • eckertb83
                                  • Jan 2011
                                  • 71
                                  ok ordered the new caps and IC once they come in and get them replaced I'll post back.
                                  • eckertb83
                                    • Jan 2011
                                    • 71
                                    OK guys I Finally got time this evening to sit down and desolder and solder the new parts on. Once I got it all together I put it back on and plugged it in and still no power. I will pull it off tomorrow and get voltage and resistance readings with the new parts on. I will be checking the resistance on the IC pins with #4 as ground and also get the voltage on PIN 8 and 6 as well as the 5v pins going to the logic board. also going to check the fuse to make sure it hasn't blown. I will report back asap
                                    • eckertb83
                                      • Jan 2011
                                      • 71
                                      IC ohm reading with no power
                                      pin 1-22kohms
                                      2-47kohms
                                      3-1kohms
                                      4-ground
                                      5-2kohms
                                      6-304k
                                      7-NA not used no reading
                                      8-500+ kohms
                                      DCV
                                      PIN 8-142-160v
                                      PIN 6-5.5-8.2v
                                      the 3-5v pins going to the logic board were reading about the same as before
                                      about 1.5v
                                      • eckertb83
                                        • Jan 2011
                                        • 71
                                        After looking at the NEW measurements it looks like nothing has changed. Even though I changed the IC and all the caps except the 2 big filter caps. To me that says theres still a component not doing its job... not sure whats next on the list to check....
                                          I have to do more thinking to see what to check next.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Thomas Smith
                                            Asus Tuf gaming fx506l no power, mosfet does not open
                                            by Thomas Smith
                                            Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                            Initial Symptoms:
                                            • The laptop has no power at all (no LEDs, no fan spin).
                                            • No 3.3V or 5V present on the board.
                                            • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                            Power Rail Checks:
                                            1. Charger input (FETs PKCH2BB)
                                              • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                            2. BQ24780S Charger IC:
                                              • VCC and ACDET are present.
                                              • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                              • Shunt resistor has 10Ω to ground.
                                            03-30-2025, 03:38 AM
                                            03-31-2024, 02:12 PM
