IBM Thinkvision 6736-HC9 No power
  • eckertb83
    • Jan 2011
    • 71
    Re: IBM Thinkvision 6736-HC9 No power
    Ok in the mean time I will start by check resistance on the small caps and resistors around the IC and see if I come up with anything that looks bad or out of the ordinary.
    • ank
      • Apr 2014
      • 8
      • Cyprus
      #62
      Has everyone given up on this? I have a similar condition, difference being that I loose power after working ok for several seconds to for ever.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4548
        • Italy - Milan
        #63
        i am come back to this thread, something in the feedback could be wrong, dismount the optoisolator and test it, one side as a normal led with dmm diode check, for the other as a C-E pin of a bjt transistor, it must read open, then you can connect a 1,5v battery on the led side, the dmm probes on the other on current test mode, if there's a current toggle the battery and the current must fall to 0.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Thomas Smith
          Asus Tuf gaming fx506l no power, mosfet does not open
          by Thomas Smith
          Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
          Initial Symptoms:
          • The laptop has no power at all (no LEDs, no fan spin).
          • No 3.3V or 5V present on the board.
          • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
          Power Rail Checks:
          1. Charger input (FETs PKCH2BB)
            • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
          2. BQ24780S Charger IC:
            • VCC and ACDET are present.
            • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
            • Shunt resistor has 10Ω to ground.
          03-30-2025, 03:38 AM
          03-31-2024, 02:12 PM
