HP-G72 output Video to VGA on boot
  • Jerry7591
    • Aug 2011
    • 30
    My son broke his HP-G72 laptop screen. I was trying to get it to boot up and output the video to the VGA port. I've tried to do this by pressing F4 on boot with no luck. Does anyone have an suggestions to try. It's hard with a broken screen to see anything. Thank You in advance.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4478
    • Italy - Milan
    Re: HP-G72 output Video to VGA on boot
    The pc brands lost their time to write manuals do you know?
    • Jerry7591
      • Aug 2011
      • 30
      I have researched this and the only information I can find is F4 on boot. I can't see the broken screen to do anything. Looking for a way to force video out to Vga or HDMI and haven't had any luck. Thanks
        Did you try Fn & F4?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4478
          • Italy - Milan
          usually in the keyboards there is a symbol of th change of screen on the F-keys, you must press Fn+that key.
          • Jerry7591
            • Aug 2011
            • 30
            Guys no go! I've tried everything . Can't get video out.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4478
              • Italy - Milan
              Read the manual, maybe there is a setting in the setup menu that you have to access blindly to set the output to the external or dual.
              • Jerry7591
                • Aug 2011
                • 30
                I have read the manual. It says to press F4 THIS DOES NOT WORK.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4478
                  • Italy - Milan
                  have you contacted HP?
                  • spleenharvester
                    • Mar 2010
                    • 921
                    VGA fuse blown? My E5500 has one so they do exist.
                    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                    • Jerry7591
                      • Aug 2011
                      • 30
                      I even tried to disconnect the broken lcd thinking it would force HDMI or VGA output with no Results. The only thing I can think is after so many boot attempts it is not loading windows 7 now. It has the option to output VGA or Hdmi and the lcd at the same time from what I have read but getting to that screen is impossible at this point. Thanks for your input guys.
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        On Windows 7
                        On a Windows 7 computer the setup procedure will be a little bit different. Rather than holding down your FN key and then pressing one of your Function keys you will hold down the Windows key in the lower left hand corner of the keyboard (the key with the Windows logo on it) and then press the P key. The keystroke WIN + P is identical to the FN+Function keystroke for older versions of Windows seen above.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4478
                          • Italy - Milan
                          you have read the setup paragraph or not?
                          • Jerry7591
                            • Aug 2011
                            • 30
                            Davi.p "I have read the manual. It says to press F4 THIS DOES NOT WORK" Have you read MY POST'S? Thanks SellDoor I will give this a whirl but i just have given to the fact that a new or used display will be the ticket. Thanks for all your help.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4478
                              • Italy - Milan
                              i have read your post but since you don't say "i have read the setup part" i cannot be sure since the F4 pressing is not part of the SETUP MENU paragraph.
                              • Jerry7591
                                • Aug 2011
                                • 30
                                For my Good friend Davi.P"Grazie per il tuo aiuto Fratello, ma non si conosce bene l'inglese che come ho detto e ho letto le istruzioni e in realtà la mia professione è un
                                tecnico elettronico per quarant'anni e oltre e cresciuto a bologana Italia rilassati bevi il tuo vino e restarne fuori, il dolore nel mio asino si è inutile". I'm sorry I had to talk to my good cume Davi.P in Italian so he new I was from the homeland. I have tried all and appreciate all the help. I've order a new LCD for my son's laptop. CHEERS!!!!
                                • FrancescoV
                                  Onkyo HT-R390 no sound output, video output ok
                                  by FrancescoV
                                  Good morning everyone,
                                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                  The firmware reported is the following:
                                  M:1.00/11107BLP
                                  D:?.??/????????
                                  O:1.00/11107AL
                                  The DSP firmware given the question marks seems corrupt.
                                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                  05-11-2025, 02:59 AM
                                • Junior††
                                  a2251 820-01949-a boot looping after screen replacement
                                  by Junior††
                                  not sure how it happened but after replacing the screen on a2251 macbook it:
                                  fans turn on for a second or 2, turn off, apple logo shows, 5-10 seconds pass and then system cuts off then cycles
                                  thermal camera shows these are getting quite hot although i'm not sure what do to.
                                  i've tried internet restore, same thing, put the old screen back on, same thing. which i'm inclined to think i f'd this up somehow or another. or the part that was given is faulty and caused something to go wrong. but I want to believe it's someone not me, but i'm prepared to think i...
                                  07-15-2025, 09:17 PM
                                • arbitarytwist
                                  Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                  by arbitarytwist
                                  Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                  Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                  03-01-2025, 01:16 PM
                                • ferah831208
                                  HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
                                  by ferah831208
                                  I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
                                  12-07-2024, 04:02 PM
                                • reformatt
                                  by reformatt
                                  07-31-2025, 08:37 PM
