need help identifying a component please
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Hi this is a 15.6" LED laptop screen LP156WH$ (TL) (CL1).
    Pno: 6870s-1128a
    lp156wh4-tla1
    Ic: US2.
    The screes is working but no backlight.
    Any help would be much appreciated
  • selldoor
    Slow Learner
    • 7870
    Re: need help identifying a component please
    What laptop is it off?
    • Bisketti
      • Oct 2013
      • 252
      • Ireland
      Its from a hpg6 but this is the screens pcb not the motherboard, the schematics dont show the LED screens pcb.
      • selldoor
        Slow Learner
        • 7870
        Ok thats where I was going - Is it burnt? Can you clean it up with Isopropyl Alcohol and
        read any more numbers off it?
        • Bisketti
          • Oct 2013
          • 252
          • Ireland
          Unfortunately no its already cleaned with IPA.
          • selldoor
            Slow Learner
            • 7870
            It may be a proprietary part anyway but can you list the numbers you can see.
            in the same grouping eg
            Top line *****
            nextline ***** and so on
            • Bisketti
              • Oct 2013
              • 252
              • Ireland
              Sorted I had an almost identical board I had cut from smashed led screen and its a Sm4500 (da1116) QFN20 Power IC Chip Chipset I repaired the damaged track and transplanted the chip and Backlight working again..Result
              • selldoor
                Slow Learner
                • 7870
                Great - I just asked Tomadochi to have a look on your other thread.
                Perhaps you can help him out?
                • Bisketti
                  • Oct 2013
                  • 252
                  • Ireland
                  It blew again after about 20mins so not sure if its the led backlights or laptop itself, back to the drawing board on this one.
                  • matheus30
                    Help identifying two components of a laptop gaming screen.
                    by matheus30
                    Good evening, can you help me with a complicated repair?
                    I'm repairing an LED screen gaming notebook. The screen has a short circuit, and when the notebook is plugged in, it won't turn on. I found the short by removing the coil in the red circle, and by injecting voltage, I see that the Richtek power supply in the blue circle is heating up. Therefore, I have located the fault.
                    But I have two problems:
                    1. The most serious is that I accidentally lost the coil, and I don't have a photo. I can also tell you that there was nothing written on it. Can anyone who has seen that...
                    04-14-2025, 04:11 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • spice_disc
                    Vizio TV M50-C1 reboot cycle and static on screen
                    by spice_disc
                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                    09-08-2024, 02:37 PM
                  • ipatch
                    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                    by ipatch
                    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                    08-24-2024, 02:36 PM
                  • HTR-Informatique
                    by HTR-Informatique
                    02-09-2025, 06:51 AM
