fixed and broken ASUS vk246
  • Grandreaper
    • Dec 2013
    • 7
    Hey guys, need a little help here. I recently had my monitor(ASUS 24" vk246) go out. After a little trouble shooting and help from this website I came to find out it had a 2 second to black problem. So I went to my local radio shack and got all the capacitors and replaced them. Still nothing so I did the cffl test, first -good second -good third -good fourth -nothing. So I went deeper and found that one of the tubes had broken at the connector. On removal the already brittle tube that came in that pair had snagged and broken. After a few days my replacement cffl tubes were in and I started the rehabilitation process. After it was all said and done I plugged it in and tad-ah it worked, well kinda. It seems to be brighter at one corner of the new cffl side. and there's a line that's always different colored. And after a few seconds the whole screen gets brighter and brighter then black. Ill be adding a video so you can see what I mean. https://www.youtube.com/watch?v=YATPqZLNXqU
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4476
    • Italy - Milan
    Re: fixed and broken ASUS vk246
    "first good second good third good fourth nothing."
    what do you mean for nothing?
    • Grandreaper
      • Dec 2013
      • 7
      Hey thanks for the response, by nothing I mean the fouth cffl was bad. The lcd still turned on, and the method I was refering to is this.
      a) TURN POWER OFF and unplug the monitor and wait 1 minute
      b) disconnect CCFL #1 and plug in spare CCFL into spot #1
      c) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      d) TURN POWER OFF and unplug the monitor and wait 1 minute
      e) reconnect CCFL #1 and disconnect CCFL #2 and plug in spare CCFL into spot #2
      f) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      g) TURN POWER OFF and unplug the monitor and wait 1 minute
      h) reconnect CCFL #2 and disconnect CCFL #3 and plug in spare CCFL into spot #3
      i) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      j) TURN POWER OFF and unplug the monitor and wait 1 minute
      k) reconnect CCFL #3 and disconnect CCFL #4 and plug in spare CCFL into spot #4
      l) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4476
        • Italy - Milan
        It arrives to me all confused.. my knowledges ara limited, as a desperate test you can try to disable the protection an run with only the old couple of lamps, disconnect the new one's side, you have to write here the marking on the bigger IC on (usually under) the psu board.
        • selldoor
          Slow Learner
          • 7870
          This was probably a mistake - the symptoms suggest a faulty panel but radio shack rarely stock caps suitable for this purpose and you did not have this problem before?
          You should replace them all again with Panasonic FR FM or FC or nichicon or
          other good make caps from digikey or a well known supplier.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4476
            • Italy - Milan
            OK so we can say: YOU MUST replace the caps... especially in the case that after the first replacement you don't ever tested the screen until the lamp replacement and noticed this ultimate defect..
            • Grandreaper
              • Dec 2013
              • 7
              Hey guys, thanks for the responses. I dont believe its the caps, for I did try to power it on with just the caps replaced. Then it worked but still had the 2 second till black problem, hence checking and changing the bulbs. I will order new caps if its really needed, but some of the caps radio shack had were panasonic.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4476
                • Italy - Milan
                Capacitors must be low esr/low impedance (different way of saying) the brand only doesn't mean enough
                • Grandreaper
                  • Dec 2013
                  • 7
                  True the brand isn't enough but as I said it was fine before the new bulbs.
                  Here are the caps I got.
                  http://www.mouser.com/ProductDetail/...0Gjvw6J33lM%3d
                  http://www.mouser.com/ProductDetail/...fEFlFAdpcQw%3d
                  http://www.mouser.com/ProductDetail/...OYLVIeEYf7E%3d
                  http://www.mouser.com/ProductDetail/...Di0pKS7kuMQ%3d
                  Also sorry I forgot to add the ic earlier. rtd2482rd
                  • Grandreaper
                    • Dec 2013
                    • 7
                    Anyone?
                    • selldoor
                      Slow Learner
                      • 7870
                      Have you checked with the seller of the lamps that they are correct for this monitor
                      Running voltage / wattage etc
                      • Grandreaper
                        • Dec 2013
                        • 7
                        Sorry it has been so long, I emailed cffl warehouse and they confirmed that the lamps I got would work. Thanks for the help so far, I hope to get this fixed, if theres any tests you think might help or if you need more pics/video just ask.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4476
                          • Italy - Milan
                          I remeber i had a monitor with a similar visual defect of screen, it was guilt of a broken pad/track near a component i had replaced. so check all the IP board bottom side..
                            by momaka
                            03-15-2023, 10:17 PM
                          • ArchangelGabriel
                            Aorus 17G YD laptop, broken display, could not switch to external monitor
                            by ArchangelGabriel
                            Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                            11-23-2023, 03:55 AM
                          • DanPoka
                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                            by DanPoka
                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                            02-15-2025, 05:05 AM
                          • ttmi100x
                            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                            by ttmi100x
                            Greetings everyone,
                            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                            Upon closer inspection...
                            07-31-2024, 06:36 PM
                          • wattage
                            AOC AG493UCX 49-inch monitor - Firmware request
                            by wattage
                            Hello Badcaps Community,
                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                            07-13-2025, 04:41 PM
