Hey guys, need a little help here. I recently had my monitor(ASUS 24" vk246) go out. After a little trouble shooting and help from this website I came to find out it had a 2 second to black problem. So I went to my local radio shack and got all the capacitors and replaced them. Still nothing so I did the cffl test, first -good second -good third -good fourth -nothing. So I went deeper and found that one of the tubes had broken at the connector. On removal the already brittle tube that came in that pair had snagged and broken. After a few days my replacement cffl tubes were in and I started the rehabilitation process. After it was all said and done I plugged it in and tad-ah it worked, well kinda. It seems to be brighter at one corner of the new cffl side. and there's a line that's always different colored. And after a few seconds the whole screen gets brighter and brighter then black. Ill be adding a video so you can see what I mean. https://www.youtube.com/watch?v=YATPqZLNXqU
fixed and broken ASUS vk246
Tags: None
Re: fixed and broken ASUS vk246
Hey thanks for the response, by nothing I mean the fouth cffl was bad. The lcd still turned on, and the method I was refering to is this.
a) TURN POWER OFF and unplug the monitor and wait 1 minute
b) disconnect CCFL #1 and plug in spare CCFL into spot #1
c) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
d) TURN POWER OFF and unplug the monitor and wait 1 minute
e) reconnect CCFL #1 and disconnect CCFL #2 and plug in spare CCFL into spot #2
f) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
g) TURN POWER OFF and unplug the monitor and wait 1 minute
h) reconnect CCFL #2 and disconnect CCFL #3 and plug in spare CCFL into spot #3
i) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
j) TURN POWER OFF and unplug the monitor and wait 1 minute
k) reconnect CCFL #3 and disconnect CCFL #4 and plug in spare CCFL into spot #4
l) plug in monitor and turn monitor on - note if "2 seconds to black" occursComment
It arrives to me all confused.. my knowledges ara limited, as a desperate test you can try to disable the protection an run with only the old couple of lamps, disconnect the new one's side, you have to write here the marking on the bigger IC on (usually under) the psu board.Comment
You should replace them all again with Panasonic FR FM or FC or nichicon or
other good make caps from digikey or a well known supplier.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Hey guys, thanks for the responses. I dont believe its the caps, for I did try to power it on with just the caps replaced. Then it worked but still had the 2 second till black problem, hence checking and changing the bulbs. I will order new caps if its really needed, but some of the caps radio shack had were panasonic.Comment
True the brand isn't enough but as I said it was fine before the new bulbs.
Here are the caps I got.
http://www.mouser.com/ProductDetail/...0Gjvw6J33lM%3d
http://www.mouser.com/ProductDetail/...fEFlFAdpcQw%3d
http://www.mouser.com/ProductDetail/...OYLVIeEYf7E%3d
http://www.mouser.com/ProductDetail/...Di0pKS7kuMQ%3d
Also sorry I forgot to add the ic earlier. rtd2482rdComment
Have you checked with the seller of the lamps that they are correct for this monitor
Running voltage / wattage etcPlease upload pictures using attachment function when ask for help on the repair
Sorry it has been so long, I emailed cffl warehouse and they confirmed that the lamps I got would work. Thanks for the help so far, I hope to get this fixed, if theres any tests you think might help or if you need more pics/video just ask.Comment
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have...
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
