Norwood Micro 19" DVI doesn't work?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I wonder if anyone has seen something like this:
    I have an old 19" Norwood Micro LCD (4:3! yay!) and Analog VGA works perfectly fine. However if I try to use DVI, it doesn't work and I don't recall it ever working because I never had a DVI output till now. I haven't had to use the DVI port because I now have other monitors whose DVI ports work, but if this monitor's DVI port worked it would make things much easier...
    Could a bad capacitor cause DVI not to work but Analog work just fine?
    Maybe something else is wrong?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4375
    • Italy - Milan
    Re: Norwood Micro 19" DVI doesn't work?
    I don't think is a badcaps related probl., unfortunately i dont have a solution, then try to access factory settings menu by in off state hold pressed 2 of the buttons then push power, usually there is nothing useful in that menu, try to do a time reset, an user setting reset, check all the double diodes on the connector data lines, more of this i don't know..
    • lexwalker
      • Feb 2011
      • 307
      • Malaysia
      First of all, did you try changing the input selection to DVI port (via the monitor control buttons)? Certainly does not sound like a badcap problem. If changing the input selection does not work then you have to start checking the area around the DVI port. Start off with those ESD protection diodes on the signal lines. Sometimes there's a resistor in series, thus check them as well...
      • Lumberjack777
        • Dec 2010
        • 464
        That's great advice Lex. Sometimes it's as simple as setting the monitor to detect DVI input.
        Another possibility is what is known as EDID corruption. It's rare but it does happen. There's a few good articles on the internet for fixing it. Here's an example....
        http://blog.komeil.com/2008/06/fixin...no-signal.html
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I just found out in parallel that it's likely EDID indeed. I did notice as Linux tried to read EDID information, it said it was corrupt. However, no dice with attempts at using the "canned" EDIDs, not sure if Linux is actually trying to use them or simply ignoring them due to some obscure bug...
          What I finally found:
          When I fresh boot the machine with the monitor attached: the default text mode worked! So the DVI port itself has to be fine. All the attempts before I had either let it boot and turned my head away, and noticed it was always stuck, or hotplugged DVI and the machine grabbed the bad EDID and did not know how to deal with it, so the screen remained blank and off.
          So now the quest is to use either my working 19" monitor's EDID or use the Linux canned EDID to see if it will wake up the monitor in DVI mode... Thanks that was interesting that EDID can be updated through DVI? I wonder if I can "fix" this for good ...
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4375
            • Italy - Milan
            If you download a casual monitor's service manual you find useful info maybe, i know edid as well as firmware ca be uploaded at least via VGA..
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I copied my i-inc 19" LCD EDID to my Norwood, and yay it looks like DVI is working!
              Thanks all. It's good to have another DVI monitor working. Now I just need to rearrange my keyboards so I can use both (I wish synergy worked perfectly but it does not...)
              I just need to fix this edid so that it at least tells me which monitor is which now...
              • Lumberjack777
                • Dec 2010
                • 464
                Excellent news. Good job fixing that
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  I didn't know EDID could be modified. Interesting!
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4375
                    • Italy - Milan
                    You changed EDID with only Linux pc and a vga cable to the graphic card? Because service manuals shows a parrallel port I2C interface to Vga/dvi and a special sw...
                    • hollox123
                      ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                      by hollox123
                      Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                      1. Laptop keyboard doesn't work
                      2. The backlight on the laptop keyboard doesn't work
                      3. The x2 side LEDs (red) on the laptop don't work
                      The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                      I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                      But I am strongly aiming that it is somehow a BIOS-related problem,...
                      05-11-2025, 08:05 AM
                    • Taurus12
                      Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                      by Taurus12
                      Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                      I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                      i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                      Any recommendation on what I have to do next? Thanks in advance
                      06-10-2025, 05:05 PM
                    • resistor83
                      lenovo 330s-15ikb, led num lock key always on and numbers don't work
                      by resistor83
                      hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                      I tried updating the bios but the problem remains
                      https://s...
                      05-29-2025, 08:06 AM
                      DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
                      I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
                      If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
                      One —>the LEDs might be bad
                      Two —> the buck converter or regular might be bad
                      Three —> the controller might not...
                      08-08-2023, 05:12 PM
                    • Rhaverz
                      My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
                      by Rhaverz
                      Good afternoon friends
                      I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
                      I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
                      I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
                      03-30-2023, 03:56 PM
