dell 2408wfpb
  • pr0ject
    • Nov 2013
    • 26
    • usa
    dell 2408wfpb
    My monitor has these boxes on it. I took it apart and looked at the capacitors I don't see anything wrong... Any help would be appreciated!
  • selldoor
    Slow Learner
    • 7870
    Re: dell 2408wfpb
    Perhaps a picture of the insides would be useful to us?
    The one you have provided is out of focus.
    Try the monitor on another source/PC/Laptop
    Try with a different cable vga/hdmi/dvi
    Try a different monitor on the current source
    What were you doing before it went like that.
    Have you soldering eqipmment and multimeter and can you use them.
    Which threads have you already read?
    • Lumberjack777
      • 464
      Re: dell 2408wfpb
      I repaired 2 of these Dell 2408wfp's with a similar looking problem about a year ago. In both instances it was the T-Con board. Basically the lcd screen showed blocks, and distorted vertical lines. I'll post the pics of them. I had to get the part number from the T-Con board. Managed to find some place in China that sold them (can't remember which outfit). And they took 3 weeks to arrive. I think they were $35 each new. Maybe they are more readily available now.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4302
        • Italy - Milan
        Re: dell 2408wfpb
        Hi, do you find that one of the few ic's on the tcon board seems to warmup too much?
        • pr0ject
          • Nov 2013
          • 26
          • usa
          Re: dell 2408wfpb
          thanks lumberjack! i haven't been able to find tcon board seller but thanks for the advice!
          • Lumberjack777
            • 464
            Re: dell 2408wfpb
            Hey pr0ject. If you could post that part number; maybe somebody could locate it for you.
            • pr0ject
              • Nov 2013
              • 26
              • usa
              Re: dell 2408wfpb
              The pn is 5edct02001 02000 834 c3kdvrd 479241 REV A00
              • pr0ject
                • Nov 2013
                • 26
                • usa
                Re: dell 2408wfpb
                Here is a picture of what I think is the t-con board.
                • selldoor
                  Slow Learner
                  • 7870
                  Re: dell 2408wfpb
                  Noooo!
                  You really need to use the search and read the other threads
                  Answering questions usually helps as swell
                  • pr0ject
                    • Nov 2013
                    • 26
                    • usa
                    Re: dell 2408wfpb
                    Okay I found the tcon board LTM240CS05FFCC4LV0.4
                    • pr0ject
                      • Nov 2013
                      • 26
                      • usa
                      Re: dell 2408wfpb
                      I just bought one on ebay. If it works out, I'll report back.
                      • Lumberjack777
                        • 464
                        Re: dell 2408wfpb
                        Good deal. That was a lot easier for you. I had to practically translate chinese to get mine
                        • Borse2008
                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                          by Borse2008
                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                          • There’s
                          07-15-2025, 04:55 AM
                        • Jesus Coder
                          Issues Reviving Old Dell 2408WFPb Monitor
                          by Jesus Coder
                          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                          06-25-2023, 02:33 PM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • DanPoka
                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                          by DanPoka
                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                          02-15-2025, 05:05 AM
                          by momaka
                          03-15-2023, 10:17 PM
