Dell U2312HMt garbled display
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Dell U2312HMt garbled display
    If there is no capacitors failure involving in this, the next step could be a soldering issue on those large IC's.
    But with out proper soldering iron station (powerful with extremely thin tip ) there is no much that you can do about re-flow all leads.
    If even that did not help, it would not be the first time that one large IC failed internally.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4367
      • Italy - Milan
      Before making the test i suggested earlier, there's 2 quarz oscillators on the Mainb., with the monitor cold heat up each of them an then power up, see what happens..
      • Richardb402
        • Jul 2015
        • Israel
        hello wondering if he got fixed his dell u2312hmt
        • dethica
          • Dec 2013
          • 16
          • Estonia
          No, I did not manage to repair it.
          • Richardb402
            • Jul 2015
            • Israel
            O.k ty I tough there is a chance to fix it
            • j0hnd0e
              • Nov 2015
              • switzerland
              #26
              Hi, I've have the same display with the same trouble...
              Any progress on this, any one?
              As I google it... It seems that the problem is not happening
              on new releases of this product A06 and newer, Sadly I got
              the A00.
              Does anyone have more informations on the design change?
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
              • F R 2568
                Dell Latitude 5420 does not start (no post) need help to find the reason why
                by F R 2568
                Hello all,
                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                If the laptop is only connected to the AC adapter (battery removed):
                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                The power/battery...
                01-08-2025, 05:45 AM
              • diamon
                Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                by diamon
                I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                Pictures of these boards:
                Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                Dell...
                02-28-2024, 12:51 PM
              • lalle-
                Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                by lalle-
                Hello!
                I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                08-11-2024, 02:01 PM
