Dell U2312HMt garbled display
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Dell U2312HMt garbled display
    If there is no capacitors failure involving in this, the next step could be a soldering issue on those large IC's.
    But with out proper soldering iron station (powerful with extremely thin tip ) there is no much that you can do about re-flow all leads.
    If even that did not help, it would not be the first time that one large IC failed internally.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4478
      • Italy - Milan
      Before making the test i suggested earlier, there's 2 quarz oscillators on the Mainb., with the monitor cold heat up each of them an then power up, see what happens..
      • Richardb402
        • Jul 2015
        • Israel
        hello wondering if he got fixed his dell u2312hmt
        • dethica
          • Dec 2013
          • 16
          • Estonia
          No, I did not manage to repair it.
          • Richardb402
            • Jul 2015
            • Israel
            O.k ty I tough there is a chance to fix it
            • j0hnd0e
              • Nov 2015
              • switzerland
              #26
              Hi, I've have the same display with the same trouble...
              Any progress on this, any one?
              As I google it... It seems that the problem is not happening
              on new releases of this product A06 and newer, Sadly I got
              the A00.
              Does anyone have more informations on the design change?
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • master3112
                by master3112
                07-29-2025, 01:55 PM
                Dell Thunderbolt Firmware
                by SMDFlea
                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                The SKU is in brackets (****)
                EDIT: NVM65...
                01-26-2025, 06:22 AM
              • F R 2568
                Dell Latitude 5420 does not start (no post) need help to find the reason why
                by F R 2568
                Hello all,
                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                If the laptop is only connected to the AC adapter (battery removed):
                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                The power/battery...
                01-08-2025, 05:45 AM
