Benq FP91G+ Monitor
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Re: Benq FP91G+ Monitor
    Originally posted by bomcla
    check thes mosfet in the inverter FU9024N e c5707 ! and 'success that face to the white screen to monitor. controls the condensers 0.22 between the C5707.
    which one's should I check?
    • killian6pk
      • Apr 2010
      • 502
      What he was trying to say is that BenQ boards have not only the 5707's but they also have another part that looks exactly the same. On the picture of your powerboard on top you can see a part location number of Q805 and next to C821 there is another one of those. I think he gave you the correct part number for them if I recall correctly. You should pull each of them and check them also as they go bad usually right along with the 5707's. Check the part numbers and list them and Bud can tell you how to test them. I have repaired several BenQ boards and each of them have had that part be toasted right along with the 5705's.
      Have you ever stopped to think and then forget to start thinking again?
      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
      • matthmal
        • Nov 2012
        • 306
        • Malta
        The model numbers are as follows:
        Q805:
        D10PF
        06
        GK05W546
        Q812:
        D10PF
        06
        GK1C1545
          Spec sheet. If this MOSFET has shorted out S to D, the backlights will be fully on bright and not be able to adjust the lamp brightness. It is driven by the PWM signal to vary the B+ feeding the backlights ROYER Oscillator output circuits.
          • lexwalker
            • Feb 2011
            • 307
            • Malaysia
            After re-soldering the C5707 transistors, I now have a new symptom. The monitor works for a while and then turns off. I switch it on again and works for a couple of minutes or hours and shuts down again.
            I tested the 3 pin voltage regulator and got the below results:
            Pin 1 -> 3.3V
            Pin 2 -> 1.8V
            Pin 3 -> 0.00V
            I still need to test the regulator when the monitor fails though as I tested it while it was on and working.
            Came across this monitor quite a few times before, and I suggest you check the primary side as well. Quite a number of them had rather "dry" main filter/smoothing capacitors (that 100uF 450V thingy). One I've fixed had major primary side failure with the main MOSFET, current sense resistor, etc all blown as well (including a dry main filter/smoothing capacitor also). Thus I would suggest replacing all those capacitors on the primary side also. Check and/or replace the current sense resistor and MOSFET (either a 2SK3264 or STP7NK80ZFP) also...
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4302
              • Italy - Milan
              #26
              matthmal i'm sorry, i've seen now that i don't have read with full attention your post, i read that you've changed only 2 5707, in that monitors there are always 4 and must be replaced all 4 'cause ususally 1 or 2 goes evidently short, the other 1 / 2 goes short under normal activity, maybe yours goes short after some minutes, i don't think you have to change things on primary side like lexwalker says 'cause you first can try the previous and at least try voltages on secondary.
              TO Retiredcaps:
              i'm unable to translate "You are going to give someone" but the message is almost clear, i think is not an huge job to put a "?" at the end of a phrase, it makes more clarity to an already difficult (for me , maybe for you is all "freshwater") theme . I don't like the smilies icon you put, i don't think i have to receive a smash from you!
