HH251 Humming and backlight issues
  • Flashgun
    • Oct 2013
    • 4
    • Italy
    Introduction
    Hi guys,
    this is my first thread but you already helped me fixing other displays quite a few times, so I'll take this chance to thank you!
    That being said, let's get to the issue:
    The Culprit
    A 3 years old 24.6" Hanns-g HH251HPB.
    Symptoms
    1. A couple months ago it had the 5-seconds-to-black issue, but after opening it up to take some reading it began working again by itself but with a "silent" high frequency humming when turned on.
    2. A couple days ago it became very dim and the brightness control had no effect (I tried setting both 0 and 100 and noticed no difference), the high pitched noise became louder even with the monitor turned off (as soon as I plugged the cord in) and I noticed that the right side was slightly brighter than the left side.
    3. Today it went in 1-second-to-black mode.
    Testing
    • No evident burning or bloating.
    • I checked the diodes and fuses and found no issue.
    • I checked with a spare working CCFL with no luck (I guess all CCFLs are working)
    • don't know if I got the reading wrong, but I found three transistor with some strange reading (circled red in the front photo)
      -Pin 1,2 and 2,3 show >20 Ohm
      -Pin 1,3 showed 0,4 Ohm
      At first I tought it was a short, but since I got the same reading on all 3 of them it seems like a strange coincidence, am I missing something?
    • I narrowed the source of the humming from somewhere in the black circle in the front photo (the component with yellow tape is some kind of transformer, right?)
    Conclusion
    I tried searching the web for some solution but I found nothing, is there anything else I can do (beside trying to change the inverters) or test?
    Thanks again for the help!
  • nutt318
    • 10
    Re: HH251 Humming and backlight issues
    Did you ever get this monitor fixed?
    I've got the same issue, it displays for around 1-2 seconds then goes black. Also it has a little high pitch sound while plugged in.
    Also If i take a flash light and shine it at the screen I can see the image. Does that mean the back light is bad?
    • selldoor
      Slow Learner
      • 7870
      Could be the back lights or the inverter transformers - see here
      https://www.badcaps.net/forum/showthread.php?t=10419 start at post19
      • nutt318
        • 10
        Thanks selldoor, I'll start working through the guide.
        • selldoor
          Slow Learner
          • 7870
          If you get stuck or dont understand just ask.
          The inverter transformers are a little unusual - hope they are ok
          I THINK the secondary winding posts are as in the pic.
          No power to monitor meter on ohms 2000 test s1 to s2 and s3 to s4
          and post the results.
          • nutt318
            • 10
            Hi Selldoor,
            The back of my board appears to be a little different, would you mind pointing out the test locations?
            Back:
            http://imgur.com/O2WffHZ
            Front:
            http://imgur.com/4oc8mDG
            Also I test all capacitors and some dont change at all on the multimeter and others will display 150ish,then 130ish, then 100ish and the to 1 or -1. Does this mean that all the capacitors are bad?
            Thank you!
            Last edited by nutt318; 02-25-2014, 08:20 PM. Reason: added front picture and testing info
            • selldoor
              Slow Learner
              • 7870
              OK we prefer pictures to be posted with " Manage Attachements" you would need to resize to 2mb - Off site ones dissappear then the thread makes no sense.
              You will need to scrape off/peel back the white insulation.
              You cant really test capacitors with a multimeter - wouldnt worry about them for now.
              • nutt318
                • 10
                Sorry about that, I'll make sure to attach them next time.
                I'll post results later tonight when I get home. However I did test test the 3 transistors last night. All 3 acting the same as below shows.
                Pin 1 & 2 - would flash a number between 100 and 150 and then go to 1 or -1
                Pin 1 & 3 - 0.8ohms
                Pin 2 & 3 - would flash a number between 100 and 150 and then go to 1 or -1
                • nutt318
                  • 10
                  I've just tested both sets of areas and my multimeter didnt change any. It just stayed on 1 on the left side of the screen.
                  I was testing them on 200ohms.
                  • Rtech
                    • Jul 2010
                    • 1095
                    If the 'areas' you tested referred to the transformers ,as pointed out by Selldoor, then the range of your meter needs to be set higher than 200Ω.
                    • nutt318
                      • 10
                      What setting should I test it with, how many ohms?
                      • selldoor
                        Slow Learner
                        • 7870
                        2000 ohms as per post 5?
                        • electrocute
                          Lenovo Yoga 3 14 (NM-A381) not powering on
                          by electrocute
                          Laptop: Lenovo Yoga 3 14 (80JH)
                          Logic Board: BTUU1 NM-A381 REV:1.0 2014-11-17
                          Issues:
                          • not powering on
                          • bottom of the laptop getting hot
                          Background:
                          Laptop not turning on. On-board voltage from AC adapter was jumping between 3V (do not recall correctly) and 4.xV, and the fan spinning/stopping on its own.
                          Initial readings:
                          Code:
                          PL202=4.12V  10.5 Ω   .010V drop  Hot Area
                          PL201=1.06V  44.1 kΩ  .320V drop  Hot Area
                          PL401=0V    55.4 Ω   .143V drop
                          PL801=0.04V  71 Ω    .050V drop
                          PL301=0V    112 Ω
                          10-28-2021, 10:44 AM
                        • SuperAman
                          PS5 HDMI port diode reading?
                          by SuperAman
                          I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                          02-03-2024, 10:16 PM
                        • SoulFreeze
                          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                          by SoulFreeze
                          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                          After repairing the above issue, I realized the following remaining problem,
                          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                          The computer recognizes headphones are connected and displays a popup in windows
                          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                          06-21-2025, 09:53 AM
                        • Nagyesz
                          Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                          by Nagyesz
                          I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                          All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                          How can I extend its lifespan? Could reflow help?
                          It has ryzen 5 5500h, rtx 2050, no soldered ram.
                          Example of the artifacts:
                          03-01-2025, 11:11 AM
                        • pwnjuice
                          Bitlocker issues
                          by pwnjuice
                          Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                          Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                          Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                          01-06-2025, 05:33 PM
